Offroad & 4x4
Winch Bumper Build
Old Mar 18, 2010 | 10:26 PM
  #121
dillinewton's Avatar
dillinewton
very good point. yamy buddy was tryin to pull some drunk guys car out of the creel, his winch pulled fine, but it also pulled his truck too would of been nice to anchor to something. good thoughts
Old Mar 18, 2010 | 10:31 PM
  #122
73 ford guy's Avatar
73 ford guy
The problem is the anchor point you need sometimes is far away so unless you carry a long rope the winch is mint. The other trick is to just have another truck in front of you and tie off to him.
Old Mar 18, 2010 | 10:37 PM
  #123
dillinewton
ya that whats my buddy did, i wasnt there but they said it took 3 cause they were pull the car up through the air off a bridge, but im not 100% sure.
Old Mar 19, 2010 | 04:27 AM
  #124
fatdan460's Avatar
fatdan460
when i was young and stupid, now i'm a little older and still stupid, i buried my truck up to the chrome trim line in a river bottom. it was one of those i can make it drunk kid moves with no after thought. my buddy with a f150 I6 4x4 was moving me until the fuzz showed up and i found out that the boat docks weren't public land. they said get a tow or get tresspassing charges, and at the time i had full coverage so i went tow. a semi tow truck was getting pulled into my truck with his pto winch. he had to call another wrecker to come down with more cable so he could attatch to a telephone pole 150 feet away from where we were at, and still had a hell of a time getting me
Old Mar 31, 2010 | 10:45 PM
  #125
73 ford guy
got some progress done today been putting it off...
I had the hardest time figuring out what I wanted to do with the ends!!
I eventually made the whole bumper 1 1/2"s thiner by cutting the whole back strip and brackets to push it back closer to tail gate all just so the end had more of a rectangle shape rather than a square end. It looks WAY better in my opinion leaving it not too bulky and very clean. I added the little piece to the body to cap the back with a 1/4 inch gap.I made the end cap on the bottom line follows the line of the box as well for a nice contour from bodyy to bumper...
Here is the current state of my truck now with the cab gutted,all aftermarket gauges,steering coulmn,line lock,roll cage, and stuff ready to be transfered to new cab. biggest pain is the hydro boost master cylinder is bolted to a custom plate welded to cab so I'll have to cut it off as well and transfer that as well. I'm overloaded with the amount of work I have right now from new motor build,body swap,bumpers, and paint.
Bumpers will eventually be powdercoated a dark metallic grey
I have a 4 day weekend coming up I hope to get a lot done as I miss driving this thing everyday. I need to finish these bumpers and start focusing on my body and motor. I've almost got all the parts I've been waiting on...
Old Apr 1, 2010 | 01:49 AM
  #126
Prozon's Avatar
Prozon
Well hey, the bumpers came out great and the truck looks good. I'm sure you'll have it up and running sooner than later.
Old Apr 1, 2010 | 01:54 AM
  #127
fatdan460's Avatar
fatdan460
i wish i had the ambition you have. f. the body. even if you don't paint match everything it will still look great, but i am a poor white trash redneck, and multi-color trucks=win to me
Old Apr 1, 2010 | 07:43 PM
  #128
73 ford guy
One good thing is the body I'm putting on is MINT. Simple sand and paint. the box is the body I'm installing. The front clip is the match to it but I have a sweet green cab to go on from a 73 again. haha just funny I got a 73 cab again I could of been maybe 79 ford guy... I did change out my front grill to the 79 style I just prefer the looks better
Old Apr 1, 2010 | 08:00 PM
  #129
fatdan460's Avatar
fatdan460
split grill all the way!!!! but that's just what i like for that body style, back when trucks still had style, class, and a personality
Old Apr 3, 2010 | 06:22 PM
  #130
73 ford guy
pretty much all welded on the rear until i ran out of wire for the last foot on the underside...
Still need to make some clevis mounts on each side with some 3/4" plate. I'll need to use my shop to punch the 1 1/4 holes..
Old Apr 3, 2010 | 07:53 PM
  #131
dillinewton
looks good man
Old Apr 3, 2010 | 08:23 PM
  #132
monsterbaby's Avatar
monsterbaby
That does look really good.
Old Apr 3, 2010 | 08:39 PM
  #133
b_eastep's Avatar
b_eastep
looks better than the winch bumper im in the middle of.
Old Apr 3, 2010 | 11:49 PM
  #134
79Ford4x4's Avatar
79Ford4x4
Those welds look nice. Shouldn't have much time in with the grinder to clean them up. You weld for a living right?
Old Apr 4, 2010 | 12:36 PM
  #135
73 ford guy
Yeah I work in a fabricating/steel shop. We do mainly new structural steel construction as well as some equipment and small stuff including handrails..
I was going to take this to my shop but my little 110 lincoln buzz box works really good. I use a smaller .030 wire rather than a .035 and it burns in real nice. I use a NR-211-mp gasless lincoln wire. Trick to this stuff is you need to switch the polarity on it making the gun - and the ground the +. Simple little wing nuts inside the cover to switch. I do have my large Miller stick welder as well and I would of used it if it were 1/4" material.
I built it all on a open corner joint so I could get full pen on the material and make a nice consistant weld.
I'll put some stitches on the inside as well. Maybe 2" every 12"s just to stiffen it up alittle more ,as well as some vertical gussets especially one directly behind were the clevis mounts will be to make that spot very strong from any flex on a heavy pull.
