Power locks, suggestions?
Old Feb 27, 2010 | 03:15 PM
64F260's Avatar
64F260
The power locks on my 2000 F250 are not totally dead, I can hear them doing something, but they dont unlock or lock. I thought they just needed some lube, but no luck. I guess its time for new ones. Any suggestions on inexpensive sources? Any pointers on doing the job, or any special tools needed?
Old Feb 27, 2010 | 03:26 PM
tacurt's Avatar
tacurt
I need to fix the locks on my Ex, there are threads that explain the process. You can open the actuator by drilling out a rivet, bypass the resistor with a solid piece of wire, and reassemble with a screw in place of the rivet. This is a simplified explination but this is what I understand is the cheap fix.
Old Feb 27, 2010 | 03:33 PM
binuya's Avatar
binuya
Here's a link to the thread:
https://www.ford-trucks.com/forums/4...cks-fixed.html
Did mine last year and been performing flawlessly since.
Old Feb 27, 2010 | 03:35 PM
64F260's Avatar
64F260
Awesome, thats great! so this mod may work to fix the existing actuators instead of buying new ones? Man, this site is great, and has saved me lots of money!
Old Feb 27, 2010 | 09:40 PM
binuya's Avatar
binuya
If you are in fact hearing the actuators trying to lock/unlock, I can be almost 100% certain this will do the trick. First one took a lot of fumbling trying to figure out how to get the actuator out. But once you do one, the rest are much easier.
Definitely worth the effort.
utjer
Jan 2, 2010 08:16 PM
SteevenH
1997 - 2003 F150
Nov 17, 2009 02:31 PM
tsworcester
Sep 23, 2006 09:54 PM
sleepysal
Aftermarket Products
Jan 12, 2005 09:18 AM
