HPOP fill plug
Old Feb 26, 2010 | 08:47 PM
origcharger's Avatar
origcharger
If its just a standard 1/8" pipe thread plug and you want to use a socket you need an 8 point socket of the appropriate size. If you don't like the square head replace it with your choice of allen, hex or slotted plugs.
Last edited by origcharger; Feb 27, 2010 at 07:27 AM. Reason: CMA in case some of the plugs are'nt 1/8" pipe
Old Feb 26, 2010 | 08:50 PM
JamesHajek's Avatar
JamesHajek
Awesome. That definitely makes it crystal clear.
EMD_DRIVER's Avatar
EMD_DRIVER
Here's a pic, that will help show you the flow of lube oil. The red tube coming up from the LPOP directly feeds the HPOP...
Old Feb 26, 2010 | 08:58 PM
JamesHajek's Avatar
JamesHajek
Thats a very helpful picture!
Old Feb 27, 2010 | 05:42 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Be carefull with the plug size, they changed mid-way through '95 like a lot of things. The early ones used a 1/8" pipe thread, then they went to the straight thread o-ring, which is what the 3/16" allen plug is.
You don't want to strip your housing trying to install the wrong style of thread if you go with a new plug.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Feb 27, 2010 | 07:04 AM
JamesHajek's Avatar
JamesHajek
I think ill just leave the plug since i will be building a tool that will fit it anyway. Its not going to be worth the hassle of switching it after ive grinded down a tool for it.
DodgeAddict
Large Truck
May 17, 2014 03:59 AM
429PI IN 75 f-100
Mar 19, 2010 08:18 PM
JamesHajek
Jan 6, 2010 05:47 PM
patrickke
Dec 14, 2009 09:44 PM
jeff7825
Nov 27, 2009 12:02 PM
