HPOP fill plug
Old Feb 26, 2010 | 07:19 PM
JamesHajek's Avatar
JamesHajek
HPOP fill plug
First off, How come Ford made the fill plug for my hpop something i need a square bit to get loose? I thought I read on here that they are allen wrench style. Well my plug on top is a square drive. Secondly, how come it couldn't be 1/4 inch? Instead its just smaller like a 7/32 or 3/16.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old Feb 26, 2010 | 07:38 PM
fordpride's Avatar
fordpride
Sounds like someone changed your plug before. you could always get one from IH
Old Feb 26, 2010 | 07:42 PM
JamesHajek's Avatar
JamesHajek
Alright i will look into that as soon as i can figure out how to get this one loose. I figured it wasn't the right plug because i went to napa and O'Reillys lookin for something square and just under 1/4 inch but neither of them had something. And i know that they should be allen wrench style plugs.
Old Feb 26, 2010 | 07:51 PM
EMD_DRIVER's Avatar
EMD_DRIVER
That seems odd to me... When I filled my 94's HPOP, I just used a 1/4" ratchet with an extension on it. It worked like a charm.....
If you have an old extension, you could grind a small amount off of each side...
Old Feb 26, 2010 | 08:02 PM
97-psd's Avatar
97-psd
that is kind of odd, mine was a 3/16 allen head, you might try to find a #3 square drive bit.
Old Feb 26, 2010 | 08:09 PM
JamesHajek's Avatar
JamesHajek
Ya it seemed odd to me when i first actually tried to open in with an allen wrench in hand and the plug was square.
So was yours square too? and thats exactly what i was thinking about doing. Just grabbin a cheap 3/8 to 1/4 drive and shaving off a little on each side until it fits.
Old Feb 26, 2010 | 08:11 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Yep... Square and the 1/4" extension went right in!
Old Feb 26, 2010 | 08:14 PM
JamesHajek's Avatar
JamesHajek
Weird. I tried putting a 1/4 extension in there but it didnt fit. Thats why ive been looking for a 3/16. Im curious if yours is a 94 and and mines a 95 and the other guys are 96+. Did the earlier year psd's have this square plug and the later ones had the allen wrench style?
Old Feb 26, 2010 | 08:22 PM
EMD_DRIVER's Avatar
EMD_DRIVER
That's what I've gathered so far...
Old Feb 26, 2010 | 08:26 PM
JamesHajek's Avatar
JamesHajek
Ok makes sense i guess. Well i will try to shave down a 1/4 inch extension tomorrow. I think my HPOP is low cuz im having hard starts. Oh when you refill it do you just use normal engine oil?
Old Feb 26, 2010 | 08:29 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Yes, that's what it works off of. The engine's low pressure oil pump is supposed to fill the HPOP.
Old Feb 26, 2010 | 08:36 PM
JamesHajek's Avatar
JamesHajek
I thought they were seperate systems?
Old Feb 26, 2010 | 08:39 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Basically they are, but the HPOP gets it's oil from the LPOP...
Old Feb 26, 2010 | 08:42 PM
JamesHajek's Avatar
JamesHajek
Gotcha. Makes sense. Well thank you for all your help!
Old Feb 26, 2010 | 08:43 PM
EMD_DRIVER's Avatar
EMD_DRIVER
Maybe this will help....
