longer than normal crank
Old Feb 26, 2010 | 01:34 PM
stroker870's Avatar
stroker870
its fifty degrees outside and my truck is taking like 8 seconds to crank. it has never had this much trouble. i changed the fuel filter and i tool my superchip programmer and i checked the engine for codes. it came up with the p1249, and 0603 which i have heard its normal for my truck to have it with a superchip. I'm trying to find a way to sell it so i can get a DP tuner but i got bigger fish to fry right now with it not cranking right. it has always turned over a twice and fired up. i checked the GPR it had 10.4 volts on the bigger wires coming in and that much on the ones going out as well. i have a 2002 f250 7.3 no mods just superchip and AFE cold air intake. its only got 105k on it now
Old Feb 26, 2010 | 01:39 PM
just another truck's Avatar
just another truck
Did you check the HPOP oil level??
Old Feb 26, 2010 | 01:44 PM
stroker870's Avatar
stroker870
im slightly new on diesels where and how do i check it? pictures are good if you have any
Old Feb 26, 2010 | 01:48 PM
just another truck
Originally Posted by maevans
Lower right hand corner you will see the HPOP and HPOP service plug.
Hopefully this works, it didnt, go to post 10 for the picture.. Good Luck!!
https://www.ford-trucks.com/forums/9...tart-post.html
Old Feb 26, 2010 | 02:11 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
How full and old is your oil?? Our injectors are fired using engine oil, if the oil is low or old it may take longer to start.
Do check what Pat said.
Old Feb 26, 2010 | 02:19 PM
stroker870's Avatar
stroker870
I know i need to change to oil but it hasn't been anymore than 10k since i changed it and the oil in the hpop its about 3/4 of an inch from the top. can the oil being that old make it do that?
Old Feb 26, 2010 | 03:54 PM
just another truck
Old oil yes.. but 10k oil, I am not sure. Are you running synthetic?
Old Feb 26, 2010 | 04:19 PM
stroker870's Avatar
stroker870
yes rotella syn. i figured out why its not cranking good i got plenty of oil in my HPOP BUT!! my oil is not registering on my dipstick. so i crawl up under my truck to take a look to see where oil is leaking and its got oil dripping off two metal lines and off a plate that covers up the fly wheel. i sprayed it down to see if i could see where any fresh is coming from and im waiting on it to dry now
Old Feb 26, 2010 | 04:24 PM
just another truck
Check the valley of the engine..most of the leaks we see are either
HPOP lines on top
Turbo pedelstal O rings
HPOP no servicable plug ( they call it that, but thanks to Guzzle, we know better)
It could be you intake boots, but I would guess not wiht as much oil as you say you are missing.
Old Mar 1, 2010 | 09:18 PM
stroker870's Avatar
stroker870
well i figured out that its my valve cover leaking oil and the water pump is leaking water. im going ahead and putting on new valve cover gaskets and putting in a new water pump as well. is my superchip a reason that my oil started leaking the oil? i wouldnt think it would but yall know more about it
Old Mar 1, 2010 | 10:28 PM
guitarpicr's Avatar
guitarpicr
Might want to test your batteries Stroker - 10.4 volts sounds a little low. I may be off on this . Somebody that knows for sure will confirm or correct me.
Old Mar 1, 2010 | 10:32 PM
Quick444's Avatar
Quick444
Is it doing this when cold only? If so it could be as simple as the GPR or the glow plugs. I have heard its actually been getting rather cold down in the South East lately.
If its doing it after the engine is nice and warm then its probably another issue.
Old Mar 1, 2010 | 11:06 PM
stroker870's Avatar
stroker870
its been 40's and 50's during the day and 30's and upper 20's lately. could it be cause i had tried to crank my truck and with the oil bein low and lugging on the engine could it be it that cause i cranked it several times and then cut it off. well its at the dealership and the batteries are only 2 years old
Swingshiftworker
Mar 15, 2014 12:25 PM
SuperDutyScaler
Computer Chips & Tuners
22
Nov 8, 2012 01:59 PM
lhud
Dec 18, 2007 09:17 PM
alarsso444
Oct 28, 2006 02:30 PM
mhogan86
Oct 8, 2005 05:31 AM
