8mpg?! REALLY?
Old Feb 28, 2010 | 12:49 PM
  #61
jroehl's Avatar
jroehl
Regarding bank-fire injectors, that gas is not wasted--it remains suspended in the air in the intake manifold until the intake valve opens and lets it into the cylinder. It is not direct-injected into the cylinder on the exhaust stroke. In addition, the oxygen sensors (when working properly) sniff the exhaust to make sure that unburnt gas is at a minimum and tells the computer to adjust the pulse width of the injectors accordingly. It's not as good as sequential-fire systems, but it's not bad by any stretch of the imagination.
Jason
Old Feb 28, 2010 | 05:21 PM
  #62
NW 150's Avatar
NW 150
wow, this is ford, not chevy
Old Feb 28, 2010 | 08:57 PM
  #63
fordman1090's Avatar
fordman1090
most of if not all the fuel in the cylinder should be burnt during combustion. But, the gas is still expanding and pushing the cylinder down when the next cylinder fires. Which wastes that remaining energy from the combustion. The amount of waste depends upon how much the combustion overlaps which is less on a 6 cylinder.
Old Feb 28, 2010 | 09:04 PM
  #64
J1nx93's Avatar
J1nx93
Whoever had the spreadsheet can you email it to me as well at tbell93@gmail.com
Old Feb 28, 2010 | 11:19 PM
  #65
skyfox10's Avatar
skyfox10
Email Sent
Old Mar 1, 2010 | 02:33 AM
  #66
TexasGuy001's Avatar
TexasGuy001
Originally Posted by BCHauler
I installed a 32 gallon Bronco tank in the rear when the stock rear tank rusted out.
I just realized that. Now its obvious why you can go farther on the rear.
Old Mar 1, 2010 | 02:38 AM
  #67
TexasGuy001
Originally Posted by bigmacmonday
mind sending me a copy of the spreadsheet you use? bigmacmonday@gmail.com
Sorry, I don't actually use one, but its a good idea.
ItsAFord55
57
Mar 15, 2024 12:24 PM
deedsF350
6.7L Power Stroke Diesel
42
Sep 26, 2010 05:33 PM
chevyassasin
Mar 11, 2010 10:49 PM
cadman70
Jan 2, 2004 11:39 PM
