Indicated speedo and odometer errors are going to be exponential. It also works the other way, larger tires=slower speedo readings and lower odometer readings. The faster you're going, the more the speedo/odo is going to be off. Kinda tough to calculate mileage that way...
The speedometer and odometer errors WILL NOT be exponential!
What's changing with the larger tires over stock tires is the distance traveled per revolution of the tire, a larger tire will travel farther in one revolution. The speedometer calculates the speed by counting the number of revolutions of the tire in a second, via the tone ring and pick-up in the rear differential, and converts it into a mile per hour reading. The odometer simply counts the number of revolutions and calculates the distance traveled. The odometer calculation is not speed dependent so the faster you go will not affect its reading.
However, to get accurate speedometer and odometer readings you should recalibrate your PSOM to compensate for the different tire circumference, as described in the above link.
Exponential was an incorrect definition, I agree. What I was getting at was that it's not as simple as adding .3 miles to whatever the odometer says.
easiest way to add for incorrect speedo calibration is a percentage.
I have a spreadsheet set up for my mileage too! Works great.
The only time my 300 got below 10 mpg was pulling a giant wooden box down the highway at 70mph. If its getting under 10mpg then there is some other issue. Even when i am trying to burn gas i dont get that low.
You also have to take into account idle time, and warm up time, which can make a big difference.
It doesnt make sense to that the 300 would get better mileage than the 302. They are basically the same size engine, with the 300 having bigger pistons, which I learned, always get worse mileage than smaller piston engines? Correct me If im wrong but, that makes sense to me.
My 302 and 5spd gets 14-15hwy and 10 in town.
300 pistons are close to the same size, but it does have a much longer stroke. The reason the 300 or any 6cyl engine get better gas mileage is because it uses more of each individual combustion. It produces the same power using less fuel. The only downside is that it make power much more slowly.
A 6 cylinder engine divides each rotation of the engine into 6 parts. So each cylinder rotates the crankshaft 60 degrees. A v8 divides each rotation into 45 degrees. In the 60 degrees that the cylinder is rotating the crank, it uses more of the energy created by the burning fuel before the next cylinder fires, where as a v8 has less time to use that remain energy before the next cylinder fires.
I hope that kinda makes sense, its kinda late for me, and things dont always come out as clearly as they seem in my head.
Also, an I6 is in perfect mechanical balance, and has fewer moving parts, which should equate to less inertia to overcome when those moving parts change direction and/or speed, and less friction.
Your numbers are a little off. In a 4-stroke engine, each cylinder only fires every other revolution. In the opposite revolution, on the down-stroke, it's pulling in the fuel-air mixture. How long a given piston/cylinder contributes to the engine's power output depends entirely on ignition timing and how long into the stroke the burning charge is exerting force on the piston. It's not as simple as 360º divided by the number of cylinders. No power stroke can exceed 180º by the nature of a piston engine--the other half-revolution is pushing the piston up in the cylinder. And there are plenty of one-cylinder, four-stroke engines, if you get my drift, and multi-cylinder engines that have overlapping power strokes, particularly engines with many cylinders, like 12, 16, etc.
Your not going to get an accurate odometer reading due to the oversized tires. So unless you use a GPS to track the mileage your not going to be able to calculate MPG's between fill-ups.
97 F250HD 4x4 x-cab longbox. 460 auto, 4.10s. 18mpg highway hauling quad and reasonably heavy right foot. Mind you I was LUCKY to get 10mpg highway empty when I got it. To date I haven't even pulled a spark plug out of it. Simply put, you have to go through it and find what's not working... sensor, plugs, whatever and fix it, then start going through the factory junk and fix it. Get the air and fuel in, get it burnt, and get rid of it. Free up the exhaust, make sure the fuel system is half decent, decent spark is a must, and... in my opinion, the factory ford intake system is garbage.
I gained most of my mileage from a K&N and basically cutting the bottom of the air box off. More warm air is better than less cold air. I always wanted to modify the hoses from the throttle body to the filter, but haven't got there yet.
