Really bad gas mileage on 302
Im gettin horrible gas mileage on my 1991 f150 with a 302. Iv changed the plugs and wires cap and rotor ..air filter..oil..it has long tube headers with glasspacks ..i think Im gettin some where between 8-9mpg
We need more info here. What transmission, gears, and tire size are we dealing with here? Two or four-wheel drive? What type of driving do you do (city/hwy)? Do you regularly make short trips (10 miles or less)? When was the O2 sensor last changed? Any exhaust leaks?
the gears are stock ...two wheel drive on 31s which I no bigger tires less mpg but there not tht big. I mostly jus around town driving. There is an exhaust tick which I think is from the header cause there is 2 factory strips in the passenger side head. The o2 sensor is on my header because I have tooken the cats off.
There were a number of gear ratios available from the factory. City driving and short trips will hurt your mileage. The exhaust leak will effect the O2 reading, which will effect your mileage as well. The O2 sensor is fine in the collector of the header, but if you've never replaced it, it would be a good idea to do so.
wow your truck is really wonkey, hotrodding for me gets me about 10 - 13 MPG and sensible driving (never going over 55MPH gets me close to the 13 - 15 some times 17 range (thats really pushing it tho lol!!!
Hmmm.....My dads' 92' XLT (302/5speed) gets EXACTLY the same MPG's as my truck (300/5speed).....
We both get 13-16 city-wise, and 18-20-ish highway...
Both are 2wd, longbed/standard cab,with 3.08 rear gears....
So yea....No one will EVER tell me that a 300 can't get as good as MPG as a 302, or vice-versa.....
i have a 302 in mine and im getting about..ehh...10-12 on city and about 15-17 on highways depending on the wind haha. the camper top effects the gas mileage on really windy days. i dunno my gear rating but i do have a 4x4 with an E4OD somaybe someone could clue me in?
