Code P0279? Hard cold start.
Old Feb 22, 2010 | 07:26 PM
PRDATOR's Avatar
PRDATOR
I have a 04 6.0 with 133k on it.
It has been getting very bad about starting when its cold 50 and below.
If I have it pluged in ( most the time) it starts okay? I took my Supper Chipps program out of it and ran it a few days with no improvment. I then ran the codes and came up with P0279 and P1000?
Can you help me out on this?????
Thanks
Old Feb 22, 2010 | 08:27 PM
sixty9cougar's Avatar
sixty9cougar
Thanks
Here is what I found
P0279: Injector Circuit Low - Cylinder 7
P1000: OBD 11 Monitor Checks Not Complete. More Driving Required
I found these in the tech folder in case you need to reference some other codes.
My truck also starts really hard when its not plugged in. I would take it to the dealer and have them test your injectors. You also might want to consider getting the newest flash update. I hear a lot of good things about it fixing the cold start issues. I'm taking mine in tomorrow for diagnostics and the newest flash. (TSB 09-24-3) I'll let you know how it goes.
Old Feb 22, 2010 | 08:34 PM
gearloose1's Avatar
gearloose1
You call 50F and below cold?
Um... I regularly start at 20F unassisted (not even plugged in), and often start it at below that plugged in, with 15W 40 dino oil.
Something else is up...
Old Feb 22, 2010 | 09:14 PM
PRDATOR's Avatar
PRDATOR
Well I dont call it cold but the truck does!! I t use to start fine in "cold" weather 10 deg but I would cycle the glow plugs a few times and she'd bust right off.
Yea there is more to it than that for sure.
Thanks for the help.
Old Feb 23, 2010 | 05:05 AM
gearloose1's Avatar
gearloose1
1. Verify battery / alternator condition as good
2. FICM voltage test
3. Synthetic 5W oil
4. Reset all electronics (disconnect battery, headlight on).
5. Latest flash
See what that does.
Old Feb 23, 2010 | 06:28 PM
sixty9cougar
A usual cold night here is around 15 Degs F. I had my truck at the dealership today because my truck starts hard and runs rough if I don't plug it in. Turns out my FICM was going bad, so I had it replaced. They also installed the newest flash for free. (since i paid mega bucks to replace the FICM.) We'll see how it turns over in the morning.
Old Feb 23, 2010 | 08:04 PM
Jayybird's Avatar
Jayybird
Just to add to to the topic. My 05 has 123k miles on it. Mine runs a little rough until the needle gets of the C. Once she warms up, it runs like a top. Before she warms up, very little power. This winter (Louisiana 20F-50F) i did switch over to 5w-40 synthetic, from 15w-40 dino. This really helped out a lot. Not real sure what the problem is, but it has me wondering......
Old Feb 24, 2010 | 07:10 PM
sixty9cougar
I'd take it to your local ford dealer and have them look at it. I brought mine in yesterday for the running rough at cold start, and low power until its fully warmed up. Turns out my FICM was bad. Had it replaced along with newest flash update. I'd also have your electrical system checked out at your local Autozone or Advanced Auto parts store. I'm told that bad batteries or alternators can cause FICM failure.
Old Feb 24, 2010 | 08:23 PM
Jayybird's Avatar
Jayybird
Thanks man for the input. Just curious, how many miles do you have on your truck? And whats the ball park price on a new FICM?
Old Feb 24, 2010 | 09:13 PM
devink's Avatar
devink
I would look at spending around $100 for a new ficm, according to questions I've asked and my dealer quoted me an estimate of $100-$110 for new one and latest flash...............
ps my truck has 113k on it and I am getting this work done Monday
Old Feb 24, 2010 | 09:15 PM
devink's Avatar
devink
oops not enough zeros...........it will be aroun $1000-$1100 my bad...........
Old Feb 26, 2010 | 09:28 PM
sixty9cougar
I have 163K on my truck, and I paid around $720 for the new FICM. After labor and programming the total bill was $870 with 10% military discount. I noticed a huge difference in the truck after the repair was done. The truck fires right up, no rough running. And I don't have to let it idle anymore before I take off. It would hesitate to shift before but that problem is completely gone now. It was totally worth the money in my opinion.
Old Feb 26, 2010 | 09:42 PM
PRDATOR's Avatar
PRDATOR
Well the truck would not start tonight so I just pulled the FICM and reflowed the few solder joints. They did not look bad at all. though the middle wire connector came loose just as soon as I turned the FICM.
Ill put it back together in the am and see what happens.
Thanks for the input...
Old Feb 26, 2010 | 11:27 PM
gearloose1's Avatar
gearloose1
Follow the repair instructions to the letter...
Oh.. follow link in my signature... and read post on checking / cleaning wiring and retest before you spend $$$$$
Old Feb 27, 2010 | 11:08 AM
PRDATOR's Avatar
PRDATOR
Well got it apart and looked at it though a magnifing glass and can see NO cracked joints..???????
So I guess Ill put it back on and see what happens...
