Sponsored by: Auxito
kift kit options
Old Feb 28, 2010 | 02:33 PM
  #46
redwood's Avatar
redwood
Originally Posted by highteckredneck
it also has the axle ratios inside the door jam. there is a sticker that has all the info, tire size, air pressure and axle info
Good point. Post up the axle code and somebody on here can decipher it for you if you don't have anything to reference. Here is my door sticker, axle code H9, toward the bottom of the sticker.
Old Feb 28, 2010 | 03:27 PM
  #47
highteckredneck's Avatar
highteckredneck
Axle Decoder Chart
Code Ratio Capacity Maker Type
12 2.73 3800 FORD REG
17 3.25 3300 FORD REG
17 3.31 3800 FORD REG
18 3.08 3800 FORD REG
19 3.55 3800 FORD REG
25 4.10. 5300 FORD REG
29 3.55 5300 FORD REG
35 4.10. 6250 FORD REG
36 3.73 7400 DANA REG
39 3.55 6250 FORD REG
45 4.10. 7400 FORD REG
49 3.55 7400 FORD REG
65 4.10. 8250 FORD REG
69 3.55 8250 FORD REG
72 4.63 11000 DANA REG
73 5.13 11000 DANA REG
H5 4.10. 3800 FORD LIMITED SLIP
H7 3.31 3800 FORD LIMITED SLIP
H8 3.08 3800 FORD LIMITED SLIP
H9 3.55 3800 FORD LIMITED SLIP
B5 4.10. 5300 FORD LIMITED SLIP
B9 3.55 5300 FORD LIMITED SLIP
C5 4.10. 6250 FORD LIMITED SLIP
C9 3.55 6250 FORD LIMITED SLIP
D5 4.10. 7400 FORD LIMITED SLIP
F5 4.10. 8250 FORD LIMITED SLIP
W5 4.10 8250 FORD LIMITED SLIP
Rcmgiasson
Mar 14, 2018 10:41 AM
mjoyce
Apr 16, 2014 12:04 PM
Mustangking1
Sep 8, 2013 03:02 PM
95f150mudder
56
Oct 24, 2011 07:24 PM
Rcmgiasson
Offroad & 4x4
May 2, 2009 09:51 PM
