1988 e250 axle code question
Old Feb 20, 2010 | 10:02 PM
fordman67's Avatar
fordman67
I am trying to locate a 3/4 ton axle with a very mild gear ratio for my project.I need to find out what a 33 axle code from an 88 e250 translates to.I was at the junk yard today and this van has no rear wheels .So I can not get under it to get any info.It is blocked i behind 10 other cars.So if I am going to make the guys dig it out. I want to make sure of what I am geting first.Thanks.
Old Feb 21, 2010 | 11:08 AM
tjc47's Avatar
tjc47
CODE 33 AXLE
According to a 1989 Econoline owners guide, code 33 is a DANA 6340#
3:54 RATIO.
Old Feb 21, 2010 | 09:16 PM
maples01's Avatar
maples01
Most have a tab on a bolt on the cover, it gives the gear ratio, what is it that you consider mild?
Old Feb 21, 2010 | 09:55 PM
fordman67's Avatar
fordman67
Thanks for that info.I am just fine on decoding the tag on the rear end.
The problem is it was buried at the junkard 5 cars deep and some genius robbed the rear wheels and put the axle on the ground.So I could not get to the tag.
I need a dana 61 from a e250. 1976-1986.There was an option for a 3.08 gear.
That is what I need.However the non u pull yard gets 800 for it.
My 1964 f250 has a 12v cummins and Allison at545.My d60 presently has 3.73 gears.With the non overdrive, non lock up trans and a 2200 rpm redline....52mph top speed! no good.
So you see I was hoping that van against the odds would get the job done.
Old Feb 24, 2010 | 10:29 PM
packlet's Avatar
packlet
bigger tires? :-)
Old Feb 24, 2010 | 10:32 PM
maples01's Avatar
maples01
Anything higher than that, will not get you better MPG but the opposite, you'll not be able to retain high gear.
Old Feb 24, 2010 | 10:56 PM
packlet's Avatar
packlet
torque at rpm doesn't seem to be the problem.
and with that setup, i doubt mileage is either...
Old Feb 24, 2010 | 11:00 PM
maples01's Avatar
maples01
I meant anything higher than 3.55, it sux, I have it in my 99 E-350 and am wanting to replace it with 4.10 LS.
Old Feb 25, 2010 | 10:43 PM
fordman67's Avatar
fordman67
The problem is with a 3.55 gear is it will only get 50mph top speed.
If I had a 3.07 at 2050rpm 60mph.The cummins 5.9 starts defueling @2k rpm.cummins range for towing is 1400rpm to 2200.3.07 will get me to a driveable range.
I believe torque will not be an issue.
Old Feb 26, 2010 | 12:50 AM
maples01's Avatar
maples01
Need to look into an OD trans, my cousin has a newer version to the 700R4 on his, think it's the 60 something. He has a new Allison in the shop, but not gonna pay what they want for the programing to run it. You could add an overdrive/under drive unit to your transmission too.
Old Feb 27, 2010 | 12:24 AM
fordman67's Avatar
fordman67
that would be great but I have an Allison AT545 auto.I have not seen anything to do an od add on .It does not have a typical removable tail housing.Also there is a drum parking brake on the rear because the transmission does not have a park paw.
I have a manual od trans but do not have the cummins to chevy adapter and they are about 700 used.I was hoping to score a 61 w 3.08 gear as it would be much cheaper.Also my wife is right that I would be sick of the stick in 3 days.
Torque multiplication will be ok as trans first gear is basically 4to 1 reduction.
skyfox10
Nov 26, 2025 08:52 AM
Brnfree
Mar 15, 2015 09:55 AM
Itch71
Sep 5, 2014 05:26 PM
RL250
May 13, 2014 01:03 PM
greg58
Feb 12, 2001 05:44 AM
