Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
r/s headlight doesn't always work
Old Feb 20, 2010 | 07:59 AM
jhayden's Avatar
jhayden
need some help here, 05 Escape 3.0 4wd. right headlight won't always come on, then other times works fine. I've replaced both headlight bulbs 3x's in 70k miles. I've repaired what i think is the ground near the washer bottle. I must be missing something here. The left side always works... help!
Old Feb 20, 2010 | 11:41 AM
bmuhlbach's Avatar
bmuhlbach
Had the same issue on the left side of my 01. I would wiggle the plug on the headlight and it would work.Cleaned the connections and put on some die electric on them works fine since.
Old Feb 20, 2010 | 02:24 PM
Dan Robertson's Avatar
Dan Robertson
You might find that there is a relay switch for each head light. Some vehicles are set up that way. Check your owners manual. The head light relay(s) are in the fuse box under the hood.
Old Feb 20, 2010 | 04:00 PM
tcesni's Avatar
tcesni
Make sure to check the plug for the light that is giving you trouble. I had the same issue and the plug looks like it has overheated at some point as the plastic is deformed.
adam1
18
Sep 14, 2015 10:54 AM
lunatech
Apr 18, 2014 11:50 PM
tw1st3d5
Jun 23, 2011 09:52 AM
wlf8383
Bronco II
Sep 11, 2006 03:18 PM
king richard
Bronco II
Aug 18, 2005 08:19 PM
