3 days ago when I first bought the truck the headlights worked. Now they don't work at all. I know the headlight switch works fine because my parking lights work normally, but when I try to turn my headlights on, nothing. I've already tried my brights and that did nothing. The fuses are not blown. What could it be? Faulty wiring? I hope not, because I don't know anything about wiring.
i had the same problem too. i'll tell you what it is. there is a short in the headlight switch that is located on the stering colum. take off the cover & tap it & it should come on. * note: i had to end up leaving my cover off, because everytime i put it back on the headlights go off & on.
My BII has given me a few headlight headaches. The first time, I traced it to a bad headlight switch. Note that headlights are an independent circuit from park lights. Just because the park lights come on doesn't mean the headlight contacts in the switch are closing. On another occasion, I traced it to a bad multifunction switch as wick972 mentioned.
Because the headlights are on their own circuit, they usually have their own fuse/fusible link. Be sure to check that.
I know it's tedious, but the proper way to diagnose this is to get a wiring diagram and a voltmeter and start testing the circuit.
