Headlight issues
Old Jun 21, 2011 | 06:46 PM
tw1st3d5's Avatar
tw1st3d5
Headlight issues
I have an 03 X Eddie Bauer V10 and both the low and high beams don't work. I've attempted to replace the headlight switch with no success. I can jumper pins 9 and 10 on the grey plug going into the headlight switch and the low and high beams work except for the "pull to pass" high beams. All of the fuses are good. I've been searching on this for over a week without any success. Where are the headlight relays on an 03? If the relay failed would it cause my symptoms? Any other suggestions?
Old Jun 21, 2011 | 08:49 PM
Shepherd2's Avatar
Shepherd2
Pin 10 is always hot and pin 9 is only hot when the headlights are on. Try jumping the DB/OG and GY/OG or/and the RD/YE and RD/BK and the multi-function switch connector. Power goes thru the MF switch to the headlights.
Old Jun 22, 2011 | 03:31 AM
tw1st3d5's Avatar
tw1st3d5
I'll try that later this evening. What are each of those wires for?
Old Jun 22, 2011 | 04:55 AM
Shepherd2's Avatar
Shepherd2
Jumping those wires is like bypassing the MF switch.
Old Jun 22, 2011 | 07:09 AM
tw1st3d5's Avatar
tw1st3d5
Those wires are in the steering column then correct? Pull both covers and I should be able to find them correct? I just pulled the wiring diagrams from alldatadiy and I now see what this is doing to check for a bad MFS but how would jumpering the 9 and 10 pin on the back of the light switch work if the MFS was bad? Sorry for all the questions but I'm more of a mechanical guy and HATE electrical stuff.
Old Jun 22, 2011 | 08:05 AM
tw1st3d5's Avatar
tw1st3d5
The more and more I look at the wiring schematics the more I think I don't have voltage on pin #8, the DB/OG wire. This comes from a 30A fuse but I've already checked every fuse in the fuse box. I'm going to start tracing the wire after work tonight from the fuse box to the switch to see if there is something wrong with it anywhere. This would cause all of my symptoms: lack of "flash to pass" and other headlight functions. Once I jumper #9 and #10 together I have power to the headlights and high beams but "flash to pass" and auto headlights are still powered off of pin #8.
Old Jun 22, 2011 | 09:02 AM
perryg114's Avatar
perryg114
See if this helps
http://www.motorcycleproducts.org/Ex.../Headlamps.pdf
Perry
Old Jun 22, 2011 | 10:52 AM
tw1st3d5's Avatar
tw1st3d5
Originally Posted by perryg114
That is basically what I have off of alldatadiy.com but it is different. I remember reading somewhere that they changed the wiring in 03 or something. Thanks though.
Old Jun 22, 2011 | 01:16 PM
Shepherd2's Avatar
Shepherd2
Pin 8 DB/OG and 10 TN/WH should be hot at all times. When you jump 9 & 10 you are basically bypassing the headlight switch. You've already replaced the HL switch?
Old Jun 22, 2011 | 01:25 PM
tw1st3d5's Avatar
tw1st3d5
Yes, I've tried to replace the headlight switch but it didn't change the situation so I went back to the original. Without looking at it till after work tonight, I am pretty sure that I am not getting voltage on #8. That one gets power from fuse 7 in the fuse box and it is good. I am going to verify that I have power to that fuse then start tracing the wire from the fuse to the back of the switch.
Old Jun 22, 2011 | 06:34 PM
tw1st3d5's Avatar
tw1st3d5
Found the issue. The #8 wire was lose in the back of the fuse block for some reason. Plugged it back in and everything works again!
Old Jun 23, 2011 | 09:52 AM
jasonodsky's Avatar
jasonodsky
HOORAY!
doublemfarm
19
Feb 11, 2021 03:05 PM
jnmescape2010
Escape & Escape Hybrid
Dec 23, 2014 07:26 AM
cabloom300
Jul 30, 2014 07:59 AM
aircropsinc
Dec 23, 2012 09:03 PM
eman resu
Electrical Systems/Wiring
Feb 20, 2007 08:56 PM
