265/70/17 to 255/80/17 possible wo lift?
I have a 2006 sd diesel shortbox with 265/70/17 stock tires. I want to put 255/80/17 BFG KM2's on the truck. These tires are 2 inches wider and about 2 inches taller. Will they fit on my beast without any lift? (Also, 285/75/17's are available, will they rub?) Thanks for any input and pics would be greatly appreciated.
Something doesnt seem right with your math. 255 is narrower than 265's so they shouldnt be 2" wider they should be slightly skinner. They are taller but still should be closer to 33" which isnt much bigger than some of the stock sizes anyhow... dont think youll have any problem. You might be accused of having pizza cutter tires though. Last time I saw 255/85/16 they are really tall and skinny - I was going to get them. Should be the same as the ones your looking at other than the rim size.
thats what i was thinking 255 means narrower than 265. you would be fine then if you are already using265s
