265/70/17 TIre Pressure
Old 08-14-2010, 09:54 AM
xjcamaro89's Avatar
xjcamaro89
xjcamaro89 is offline
I know this has been discussed several time. And i searched and couldnt find a good answer. I got a set of Firestone Destination LEs in 265/70/17. The stock size is 255/70/17 at 35 psi. What would the correct pressure for the 265s be to keep proper tire wear? is the 35 psi still a correct pressure? Thanks!
Old 08-14-2010, 10:04 AM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
It should be close.....but the best way to determine that is put some paint on the treads and let it dry.....go drive around the block and see if its wearing off evenly.....
Old 08-14-2010, 06:20 PM
Oldguy4's Avatar
Oldguy4
Oldguy4 is offline
For what it's worth my truck came with 265/75/18's and also calls for 35psi.
Old 08-15-2010, 05:58 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
tire tracks
As mentioned, wet the tires and drive slowly in a straight line to see if the tire footprint is making a full print. I also keep an eye on my tires to make sure they are wearing evenly. Outside tread wearing faster...not enough air. Inside (middle) tread wearing faster... too much air. I also get my tires rotated at recommended intervals, and my BFG KO's are wearing perfectly. I usually get them balanced because a lot of times a weight is gone or the tire has changed. I've bought all of my tires at one place, and they will do all of this for free, but tips are appreciated.
Old 08-15-2010, 07:19 PM
jstnromero's Avatar
jstnromero
jstnromero is offline
I keep mine at 40
Old 08-16-2010, 02:36 AM
OptimusF150's Avatar
OptimusF150
OptimusF150 is offline
It depends on the tires rating the load range of the tire. A load range D and a load range E has 2 different psi settings. Doesn't your tires tell you the psi on them?
Old 08-16-2010, 04:51 AM
svt2205's Avatar
svt2205
svt2205 is offline
Remember that the tire pressure shown on the side wall is the max pressure to achieve the max rating of the tire. This is not what you need to safely run your tires when the vehicle is not at max load capacity.
Bumping up one tire size, you're fine running the stock pressure recommendation. Ryan's method of checking for full contact will tell you if 35 is ok. Which I'm sure it will be.
Old 08-16-2010, 08:04 AM
EBTDM's Avatar
EBTDM
EBTDM is offline
Really?
Go with the tire pressure is on your door post. Then watch the wear and alignment issues.
We all should be doing that anyway.
My F150 HD calls for 60lbs. I run load range E and 285/70/17 at 55lbs in the front and 50lbs in the rear unless I have a have a heavy load then it is 65 in the rear. This is a larger than stock tire.
You have to watch your tire if you want to get a longer usage life from it.
Fyrfyghtr
10-21-2016 09:09 PM
Pshicker
1999 to 2016 Super Duty
10-16-2016 08:22 AM
Diving Junkie
2004 - 2008 F150
12-24-2015 07:09 AM
ErricZ
03-17-2012 08:30 AM
Hubnut
02-23-2010 10:10 AM
Quick Reply: 265/70/17 TIre Pressure
