Hi. New to forum, thought id try it out. Ive always run the recommended P255/70R17 tires on my truck but came across a great deal on a set of 265/70/17. Would I risk causing any damage to truck by switching to the 265's? I know its only a change in the width and not height but wanted to hear another opinion. Thanks. And the truck is a 2006 f150 stx 4by. and I don't know squat about cars. Thanks
The difference calculated to be about 1.77% so I think it would be okay to use.
BTW, whenever there's a change in width there will be a change in height too. because the first number is width, but the second number is the ratio percent of the width.
It's not going to break your truck, but be prepared for a potential loss of traction in wet or snow.
The wider footprint distributes the weight of the vehicle over a larger area, which means the vehicle can float or hydroplane more easily.
It seems counter intuitive, but a narrower tire can actually provide more traction than a wider tire.
Having said all that, a difference of 10mm isn't likely to put you in the ditch.
