Offroad & 4x4
Another tire size question
Old Dec 31, 2015 | 01:48 AM
54hillbilly's Avatar
54hillbilly
My 2000 F150 4x4 Off Road is bone stock. It's time for some new tires and wheels. Right now I have 17" wheels and BFG 265/70/17s on it. I was thinking about going with an 18" wheels? and a little bigger tires. I was going to add a 2" torsion lift to the front to level it out. What size tires do you all recommend? What brand? (on/offroad). Later on I plan to add duel exhaust and a few other things. Thanks in advance.
File Type: html
Old Dec 31, 2015 | 09:21 PM
54hillbilly
Thanks for any advice. I need tires ASAP.
Old Jan 1, 2016 | 08:57 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
your current tire size is 32 X 11.50 X 17
i can see no reason why you could not put a 285/65R 18 tire on the truck with stock suspension, the 285/65R 18 is 33 X 11.50 X 18, or 1 inch taller.
the only issue i can see you running into is finding an 18 inch rim that fits your truck.
if i remember correctly, you have 5 lug wheels, and the 18 inch wheels are 6 lug.
Old Jan 1, 2016 | 09:32 AM
Nothing Special's Avatar
Nothing Special
Originally Posted by tjc transport
.... the 18 inch wheels are 6 lug.
??? 18" wheels are only made in 6 lug? I could have ordered 8 lug 18" rims with my '08 F-250. I gotta believe they're made with other patterns too.
As far as brands, you'll get almost as many opinions as you have people answering. Personally I like BFGs, although I've never used the new M/Ts, so I can't say anything about them. And I recently got a set of the AT KO2s, so not much experience there.
Old Jan 1, 2016 | 09:58 AM
54hillbilly
Thanks for the help y'all..Dealer guarantees wheel fit but I will make sure. I was thinking about going with Nitto Terra Grappler G2 blackwall tires. Wheels I was quoted on were Tuff T10 matte finish 18x9.With the few miles I put on my truck per year I guess any decent tire will do. They usually deteriorate before they wear out. I basically use the truck at the hunting club with no serious off road obstacles. As I get the money to do add ons I will check back with this forum for suggestions. That is one nice Bronco Nothing Special! Happy New Year Yall.
Old Jan 1, 2016 | 10:03 AM
tjc transport
i ain't rite
i was talking about the stock F150 18 inch rims when i referred to the 6 lug pattern Bob.
Old Jan 1, 2016 | 10:24 AM
54hillbilly
It's a 5x135 bolt pattern. So newer stock wheels won't fit. I am going custom.
Old Jan 1, 2016 | 01:38 PM
tjc transport
i ain't rite
should be no problem with aftermarket wheels. just make sure you get the proper backspacing.
Old Jan 3, 2016 | 11:20 AM
54hillbilly
What is the proper backspacing? 5.5?
Old Jan 3, 2016 | 01:38 PM
tjc transport
i ain't rite
no idea, i never owned a 150. and the only one i ever really worked on was replacing a bad ignition switch on a 87 for a friend
ktnissen
Nov 28, 2014 09:20 AM
btacarlton
Nov 10, 2014 06:28 PM
Skip1970
Mar 27, 2010 02:38 AM
sbclemens
20
Dec 22, 2006 10:31 PM
mrblack
Jul 28, 2002 08:49 AM
