Sponsored by: Innova
Remote start wiring harness
Old Feb 19, 2010 | 05:35 PM
maples01's Avatar
maples01
OK, I know there is a harness that plugs into your factory wiring that you wire your remote start to, so you can simply unplug it to go back to factory without a trace. I refuse to crawl under my dash and cut into the factory wiring of my 99 Econoline, but I need this to make starting it easier, allows it to warm up, and prefer it to be running when I use my wheelchair lift, it's a power hog.
Old Feb 19, 2010 | 10:51 PM
Rickx's Avatar
Rickx
Do you already own the remote start hardware. If so what brand and model. Is it part of an alarm system that you are installing?
Old Feb 20, 2010 | 12:54 AM
maples01's Avatar
maples01
It's a 1-Start remote start and alarm, OS-127XR Series.
Old Feb 21, 2010 | 07:32 AM
ReAX's Avatar
ReAX
Bull dog security is the only company I've seen with a plug and play install harness. The vehicle didn't come with a single extension harness just for aftermarket r/s installation.
They've changed their website recently, but take a look or call them. Bulldog Security
You might also need a PATS module. It might be preferable for you to take it to a certified installer and have it done for you.
Old Feb 21, 2010 | 10:23 PM
maples01's Avatar
maples01
I had the bulldog one ordered, but on back order so long I decided to cancel, may try elsewhere, most places prefer you buy from them to get it installed, not sure I'd get a deal on an install.
Old Feb 21, 2010 | 11:20 PM
lariat97's Avatar
lariat97
I got my alarm & remote start in my 97 F150 installed for the same price as buying it & putting it in myself. My shop installs them free with the purchase.The install isn't a expensive deal for a good shop. It doesn't take long to install & they have the wiring detail on their computer to use to find where to hook it up.
Old Feb 21, 2010 | 11:42 PM
maples01's Avatar
maples01
I bought this one already, an extended range type, wanted the T-harness to make it an easy install that can be quickly removed if I was selling the van or it malfunctioned.
Old Feb 22, 2010 | 05:22 AM
ReAX's Avatar
ReAX
For the malfunction side, a single fuse on the power feed will give you that option. Just fuse the constant/battery wire. Then if you have difficulties, remove the fuse to disable the r/s. If you wire the starter interrupt correctly, it will work as factory when the brain doesn't have power.
Old Feb 22, 2010 | 09:26 PM
maples01's Avatar
maples01
I have a friend, his had to be completely removed, it was causing his problems of not wanting to start and run, he was using the key, anytime you have to link something between the ignition wires there is a chance it can keep you from starting it.
jimbomitch
29
Apr 4, 2018 07:56 AM
79BRNC
2011 - 2019 Explorer
Mar 30, 2017 04:32 PM
reptar0077
Jan 20, 2017 08:43 PM
Bryan Hagan
Dec 19, 2015 07:50 PM
PowerStrokeHD
6.7L Power Stroke Diesel
25
Jan 28, 2013 06:54 PM
