What is this for?
Old Feb 19, 2010 | 04:48 PM
megawatt00's Avatar
megawatt00
Your more than welcome. You can order an AIC from the dealer or look around on CL or EBay. They are used to kick up the idle on our trucks to warm them up quicker or when jump starting another vehicle. Chase (superduty 4x4) has one in his truck we wired his differently though. To fool it into thinking that the ebrake is on via a switch
Old Feb 19, 2010 | 05:52 PM
Pappyoutlaw44's Avatar
Pappyoutlaw44
Thanks guys, I felt that I could find the answers I was looking for from
the FTE.
Mike
Old Feb 19, 2010 | 10:13 PM
onelionhunter's Avatar
onelionhunter
Ebay
Here is one on ebay
7.3 diesel aux. idle control module : eBay Motors (item 320490561493 end time Feb-25-10 19:45:02 PST)
Old Feb 20, 2010 | 12:05 AM
aldridgec's Avatar
aldridgec
I have one that is new in the box, never used. If you really want one, PM me.
Old Feb 22, 2010 | 10:09 AM
superduty4x4's Avatar
superduty4x4
PTO control model?
To add to what Jim said, I have an AIC installed in my truck. Its a plug and play deal, basically it lets you adjust the idle up for warm ups, jump starting, etc. Or, if you get the one that can control a PTO and your truck is actually equipped with one you can use it to run that. Mine is wired with a toggle switch to make the truck think the e-brake is set so that the AIC will operate. For the AIC to operate the following conditions must be met:
Truck in P (auto) or neutral (stick)
E-brake set
No input to go pedal or brake
The factory e-brake sensor is a cheesy little piece of crap and one spec of dust can cause it to not work properly, so when you set the e-brake the light doesn't come on. No light = no AIC operation. With the toggle switch I installed I flip the switch to ground the e-brake circuit and turn on the light in the dash. It was a really simple install.
Old Feb 22, 2010 | 02:01 PM
C-TAN's Avatar
C-TAN
Does anyone know what the rectangular plug to the right of the AIC is?
I have been trying to identify it for a while now.
Old Feb 22, 2010 | 04:52 PM
maevans's Avatar
maevans
OBD-II port. On—Board Diagnostics Second Generation. A system that monitors PCM input and output control signals.
Old Feb 22, 2010 | 05:11 PM
aldridgec's Avatar
aldridgec
Originally Posted by superduty4x4
PTO control model?
I don't think so, but i will have to check.
Old Feb 22, 2010 | 05:56 PM
big poppa's Avatar
big poppa
Unless you using it to power up things like use of a PTO, basicly its like Jody's tune for a high idle, correct?? Disregard, read Marks AIC user directions, nice..
Old Feb 23, 2010 | 09:50 AM
C-TAN's Avatar
C-TAN
Thank you very much, I appreciate it.
9d4
Oct 26, 2012 12:18 PM
JaySVX
Sep 29, 2009 08:07 PM
r1200gsa
May 25, 2007 08:52 AM
bowhunter 1963
Jun 24, 2004 07:25 PM
