What is this for?
Feb 19, 2010 | 02:08 PM
What is this for?
This is under my dash of my truck just to the right of the steering column.
2002 F-350 XLT, 7.3 PS, CC, 4X4, CC, DRW. Auto w/OD.
What would this be for?
Feb 19, 2010 | 02:15 PM
I wished I could blow that picture up.I hate to say because I am not sure of the picture????
Feb 19, 2010 | 02:16 PM
It is for an auxiliary idle control but I can't tell from the pic whereas I am looking at it via a phone.
Feb 19, 2010 | 02:19 PM
I edited my post and removed the original picture and put another picture in.
Maybe you were looking at my post while the picture was removed?
Maybe hit refresh and look again? Thanks.
I may be able to put a larger picture in, if need be.
Feb 19, 2010 | 02:21 PM
I see the same size picture with a plug circled in yellow.Still not sure what the plug is for.
Feb 19, 2010 | 02:22 PM
I see the picture now, but bigger would definitely be better. I can't make out what it is, but I probably wouldn't know anyways, so pay me no mind.....
Feb 19, 2010 | 02:32 PM
I'll take another picture
I'll take another picture, the plug is blurry in this picture.
And post the picture in another post on this thread.
Feb 19, 2010 | 02:49 PM
here is a larger picture
Here is another picture, hopefully you guys can help me out.
Thanks.
Feb 19, 2010 | 02:55 PM
If I were a bettin man, I'd say it is for the AIC unit. Pretty sure that is where the female receptical is located on my truck.
Feb 19, 2010 | 03:45 PM
Fairly New Poster
Ok, Just what is an AIC Unit?
Some of these abbreviations I'm unable to sipher them out.
Feb 19, 2010 | 04:19 PM
Quote:
Originally Posted by
megawatt00
Pappyoutlaw44
Feb 19, 2010 | 04:26 PM
can you order an AIC from ford to retrofit if you have the plug or is there a PCM parameter that needs to be enabled.
Feb 19, 2010 | 04:38 PM
megawatt00
Thanks for the info...........What would you use this for?
What would you hook to the plug in the picture?
Feb 19, 2010 | 04:46 PM
Pappyoutlaw44
This should explain what it is and what is does -
AIC Operation Manual
