Sponsored by: Real Truck
blower motor quit?
Old Feb 19, 2010 | 07:52 AM
GooseTrailer's Avatar
GooseTrailer
blower motor quit?
I am new to this site. I am an original owner of a 2000 F350 7.3L 6spd crewcab 4door with 255,000 miles. Recently, my blower fan in the cab quit. I have heat, but no defrost air. Where do I start to repair this problem?
Old Feb 19, 2010 | 09:24 AM
senix's Avatar
senix
Do you have the automatic climate control or manual switches? Does your fan speed default to high.
did you check your fuse for the fan?
Old Feb 19, 2010 | 10:07 AM
GooseTrailer
I have manual controls for the fan.
Late last summer, it would operate on the low setting and only operate on the high setting. No difference on medium setting.
Last fall, it just quit.
I just checked the 40 amp fuse and it is blown. Wow, that is a huge fuse! What would cause this?
Old Feb 19, 2010 | 10:09 AM
senix's Avatar
senix
hard to say but it might be the blower motor resistor or the motor itself that is bad. If it blows again I would look there.
Old Feb 19, 2010 | 10:10 AM
GooseTrailer
sorry typo on last message - it would not operate in the low setting, just the high setting.
GooseTrailer
where is the blower resistor located?
Old Feb 19, 2010 | 10:25 AM
senix's Avatar
senix
Then it is the resistor. should be located on top of the blower motor housing.
Old Feb 19, 2010 | 10:47 AM
GooseTrailer
Could you please be more specific - perhaps a part number??
The only thing I see electrical on top of the housing is a small electrical item part number 98AB 9F479 BA or PBT-GF30. It has 2 screws holding it, the AC dryer is below/front of this, & it has electrical connections & a vacuum hose from intake attached to it??
There is another item located inside the housing behind the AC dryer where electrical fittins plug into??
There is another item bolted to the sidewall fender that has electrical & vacuum lines??
Old Feb 19, 2010 | 11:43 AM
senix's Avatar
senix
see the link from autozone: AutoZone.com | Vehicle Selection | Year
Old Feb 19, 2010 | 11:45 AM
senix's Avatar
senix
link may not work but it is 24 bucks online part #
Part Number: SW3316
Weight: 0.1 lbs
Application: Manual temperature control
Notes: Heater switch
Quantity Per Car: 1
OEM Number: F65Z-19986-AB
Old Feb 19, 2010 | 12:14 PM
GooseTrailer
Senix - Thanks.
I called my Napa partsman after I posted the last time and asked him about this resistor. For future reference: The Ford blower motor resistor is a Napa part # BR348 @ $15.99 each. And, it is the item located inside the housing, just to the left (drivers side) of the fan motor and slightly behind the AC dryer where electrical fittings are plug in. It is bolted in with 2 - 5/16" lug screws. I hope I don't break the plastic ears off the wire harness? Thanks for directing me in the right way.
Old Feb 19, 2010 | 12:15 PM
senix's Avatar
senix
Some have three bolts as well, so just be as careful as you can.
spook222
Aug 11, 2016 10:32 AM
Chris McCarthy
6.4L Power Stroke Diesel
Jun 2, 2016 06:36 PM
CGMKCM
6.7L Power Stroke Diesel
May 13, 2016 01:43 PM
f150STX27
New Member Introductions
Apr 21, 2016 04:33 PM
wolfsbayne
Aug 29, 2003 05:30 PM
