Replacement hard drive
Old Feb 16, 2010 | 11:35 PM
ford2go's Avatar
ford2go
I've got a Dell 2400 -- around 6 years old. I'd like to replace the hard drive just to be safe -- plus it's a 30 gig ( how times have changed)
Does anybody have a suggestion for a reasonable choice? When I look around, there seem to be mostly SATA drives, and of course mine is older than that. (I don't keep up, but I think they call my type PATA these days).
Also, I would want to be able to just image my existing one -- I've heard that that's common, but i want to be sure. I have an external USB drive if some temporary storage is required.
Thanks,
Old Feb 17, 2010 | 01:03 AM
donjamer's Avatar
donjamer
Thanks,
They still sell PATA or IDE hard drives, but mostly online if you want any type of selection.. If they have them on stores, then they usually have 1 or 2 and usually large size like 250GB..
Seeing that it is an older PC I would recommend staying with a 160GB just in case the BIOS doesn't handle a larger drive.. IT should take a 160Gb one..
YOu can find 80Gb drives also, but you will probably pay more than a 160Gb drive..
Check out Newegg.com
Here is a link to the 160gb drives
Newegg.com - Computer Hardware,Hard Drives,Internal Hard Drives,100GB - 200GB,IDE Ultra ATA100,7200 RPM=
Here is all the PATA drives..
Newegg.com - Computer Hardware,Hard Drives,Internal Hard Drives,IDE Ultra ATA100=
Old Feb 17, 2010 | 04:57 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
The ONLY thing that I'd like to add to what Don posted, is. . . .
Go with the Seagate drive, or, if you can find one, a Maxtor!
I used to be a Western Digital hdd fan. I've had three (3) go bad, one right after the other.
(One hdd was less than a year old. It was my daughter's, and she came very close to losing some irreplaceable photos!)
I talked to a data retrieval guy, and he said that WD's quality is not what it used to be.
Also, I think that Seagate's warranty is the only one that's still for 3 years (or longer).
Munkey
Feb 19, 2007 07:56 PM
96P_Stroke4x4
Jan 31, 2004 11:11 AM
BuiltToughF250
Dec 28, 2003 09:32 PM
CowboyBilly9Mile
Dec 21, 2003 01:41 PM
fatdaddy
15
Mar 25, 2003 05:15 AM
