Needing Notebook Hard Drive HELP!!
Old Feb 18, 2007 | 10:35 PM
Munkey's Avatar
Munkey
The HD on my notebook is about to bite the dust, it's got all the classic symptoms. I haven't cracked open a notebook, or a PC since like 1999 so I'm lost on the 'new' technology.
The current HD is of the Ultra-ATA/100 variety. I'm finding replacement 2.5" Ultra-ATA's to be few, far-between, and friggin expensive!
If I've got ATA/100, then ATA/33 and ATA/6 should be backwards compatible, right?
Also, with the new HD, I want to completely ghost the current failing HD to it. Can this be done with just the new drive in an enclosure? In other words, can I just hook up the new HD in an enclosure, plug it in via USB (or serial, or parallel??), and copy the old HD to the new one? Any good software to use?
Any help would be appreciated, because if this HD goes, I'm FUBARED cause I didn't back up anything!
Old Feb 18, 2007 | 10:46 PM
donjamer's Avatar
donjamer
That is the benefit of buying a laptop.. They are more expensive to fix.
Compusa has hd's for around $70.00 I believe..
I believe they are ,but they are probably harder to find.
Can you still boot to the old drive? If you can't then Ghost will not work properly. You will end up with junk.
If you can then create an image as soon as possible..
If the drive is dead already then you will probably be able to connect it with an enclosure then copy files off..
Try running Chkdsk on the drive if it usable. This may be able to recover some damaged data enough for you to get it off..
Old Feb 18, 2007 | 10:52 PM
furball69's Avatar
furball69
Interesting. Copying files off a dead drive is something I could never figure out. Could you explain the process?
Old Feb 18, 2007 | 11:26 PM
donjamer's Avatar
donjamer
Furball,
By dead I mean, it can't run as a boot drive....but the computer still recognizes it.
Some drives can be connected with an enclosure and run long enough to be able to transfer files.
I have done this with many drives. When they are connected I run scandisk or chkdsk and repair them.
This allows you to recover most if not all files..
It depends on the drive and how it is damaged...
Old Feb 19, 2007 | 12:10 AM
Munkey's Avatar
Munkey
Heh, actually, I'm still using the old drive as we speak!
It crashed right as I hit "Post Quick Reply", and it took WinXP 3 reboots to get everything working again.
Ok, so looks like I'm heading down to the computer shop to pick me up a new HD ASAP.
Any software recommendations, or how-to's on how to completely copy the current HD to the new one?
Oh, a thanks a ton guys!
Old Feb 19, 2007 | 12:29 AM
donjamer's Avatar
donjamer
If it is working and you have ghost then create an image to cd or dvd. then when you get the new drive just install the image after booting to the ghost cd.
Maxtor has a program that ships with their drives called maxblast. This works if the old drive is a slave and the new one a master. I don't think it works if you connect one via usb.
I would go with the Ghost image method
Old Feb 19, 2007 | 04:01 PM
97ranger xlt's Avatar
97ranger xlt
my son just got this - i can't believe you can get a 2 gig flash drive for $20 now...
http://www.cdrdvdrmedia.com/2gb-pqi-...sb-2-gold.html
Old Feb 19, 2007 | 06:58 PM
angus's Avatar
angus
If you suspect the windoze installation is at all corrupt on the old drive, do a fresh install (or use the recovery CDs that came with the laptop) to the new drive, then just recover the important stuff (mail, photos, work) from the old drive. What with fragmentation, spyware, old junk in the registry, starting with a fresh install makes a lot of sense.
Old Feb 19, 2007 | 07:56 PM
Munkey's Avatar
Munkey
Angus,
No dice, somehow, between getting married and moving, I've lost all the recovery CD's that came with this laptop. Hell I woulda done that five times over already!
Talked to a local shop today, and they'll scan, fix, and clone my current drive for $60. Sounds damn good to me considering I'll probably screw something up in the process!
Thanks for the replies!
sierraben
18
Mar 12, 2008 08:30 PM
Matts72
27
Aug 5, 2005 01:05 AM
CowboyBilly9Mile
Dec 17, 2003 10:54 PM
fatdaddy
15
Mar 25, 2003 05:15 AM
