HELP !!!! hard drive installation
Old Dec 28, 2003 | 05:37 PM
BuiltToughF250's Avatar
BuiltToughF250
ok i bought a higher spaced hard drive, and opened up my tower. but my problem is, do i remove the original hard drive and replace it with this new one, or do i just ADD this one ?? it doesnt say in the directions.
Old Dec 28, 2003 | 05:44 PM
BuiltToughF250
ok on the new hard drive there is a clip i need to put in to choose whether it is single, dual ( master ) or a dual (slave) hard drive.
then on the connecting wire for the original hard drive, and the new hard drive, there is a clip in the middle where i can plug in another connector like as if i am using 2 hard drives ( dual )
so if i have to use both of them, which connector do i plug into the motherboard and then do i join the 2 connectors together?
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
If your computer has one hard drive now, you can have two. I assume your hard drive came with an extra IDE cable in the event that you need it. If you have two hard drives now, you might just need to get a card to run hard drive #3.
Old Dec 28, 2003 | 05:48 PM
Matts72's Avatar
Matts72
You want to run two HD's, until you get the info transferred from one to the other. Make one of them the slave drive.
Old Dec 28, 2003 | 05:49 PM
CowboyBilly9Mile
I just email'ed ya my cell fone #, feel free to call and ask. You have a couple of choices available to ya.
Old Dec 28, 2003 | 06:05 PM
MisterCMK's Avatar
MisterCMK
You will want to add the new hard drive as a slave to the existing drive. That way you don't have to reinstall windows and all your programs.
Old Dec 28, 2003 | 07:57 PM
BuiltToughF250
COWBOYBILLY and everyone else-
i seem to have gotten the new hard drive installed properly, and my computer is running a little bit quicker. only problem is that im still having a hard time getting aol changed back to 8.0 or higher, this aol 5.0 is just miserable. is it possible that i need to completly un-install AOL and reinstall it?
also i bought a ultra ATA card that is suppose to be made to adjust a computer to use more ram space but i havent opened it yet. it was 40 bucks, should i install it just for the heck of it, or just take it back for my money?
Old Dec 28, 2003 | 07:59 PM
Andysutt's Avatar
Andysutt
I'd add the other one, keeping both
They have pretty well explained how to do it above.
I dont know about the ram space thing
But I have had to install a controller to hold bigger hard drives and more of them once
Old Dec 28, 2003 | 08:01 PM
Matts72's Avatar
Matts72
You really should dump aol.
Thats the best thing that you can do for your compy health.
Old Dec 28, 2003 | 09:32 PM
CowboyBilly9Mile
Good to hear the new drive is up and running. I assume you made it a slave drive and will most likely use it for data storage.
I really can't help ya with the AOL; I'm not a supporter of them in the least but I realize that some folks love em. My guess (note guess) is that you should be able to delete your current version and install whatever you want so long as it's still supported. But this brings up one of my many AOL peevs; after you uninstall it STILL leaves crap behind; maybe there are some exceptions but that's what I've seen. If this will cause problems for you I have no idea; I would call them for support.
As for the ATA card, I'd take it back provided that your computer recognizes ALL of the space on the new HD. For example, I know that Win XP will only recognize up to 137GB unless you take certain measures (such as SP 1). I think W98/W ME only recognizes 32GB unless you take certain actions to address this; one action would be to install that ATA card. Just do your homework on this one to ensure that there will be no data loss down the road.
fatdaddy
15
Mar 25, 2003 05:15 AM
