Remove wire from starter
Old Feb 15, 2010 | 12:14 PM
fuzzy1626's Avatar
fuzzy1626
Is it possible to disconnect and replace the wire that run from the fender solenoid to the starter (remove at the starter) with the starter bolted in the truck. I don't know if I can get my old fingers in a tight spot like that anymore.
Old Feb 15, 2010 | 12:48 PM
WarOzz's Avatar
WarOzz
I did it but I had the help of my son with smaller hands.
Old Feb 15, 2010 | 01:06 PM
fuzzy1626's Avatar
fuzzy1626
Thanks WarOzz. It is a very small stud and nut, correct ?
Old Feb 15, 2010 | 01:38 PM
WarOzz's Avatar
WarOzz
if your talking the switch wire... yes like 5/16 IIRC
Old Feb 15, 2010 | 02:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Disconnect the batteries, then you should be able to use a 1/4" drive rachet and get the nut off.
Old Feb 15, 2010 | 02:41 PM
wreckinball's Avatar
wreckinball
yep, 1/4 inch drive with a small extension is what i used as well!
oneborn2fly
Nov 17, 2014 06:58 AM
PatrickFD
1983 - 2012 Ranger & B-Series
Mar 6, 2012 05:33 PM
CDaddy
Oct 10, 2010 08:17 AM
russkiypenguin
Nov 4, 2004 10:25 PM
