F10= 1/2 ton 2WD truck
Y = 352 engine
K= Kansas City assembly plant
768947= Oct. 1965 build date..1966 model
WB-115" = shortbed truck
F= exterior color = Light Blue
F100 = truck model...1/2 ton truck
281= interior trim code and body type...2= Medium blue crush vinyl and medium blue wicker pattern vinyl.
81= 81A= base model conventional cab truck
C= Transmission = Ford medium duty 3 speed.
08 = rear axle ratio...3.50 axle ratio non locking, 3.3M capacity
5000 is trucks Max GVWR in pounds with people and cargo.
172@4000 is the engines certified NET HP at specified RPM
63= DSO...where the original selling dealer ordered the truck from..Memphis in this case.
what's the difference between the promotional name and the actual color? If you went to a paint shop not knowing the paint code and you just said light blue I'm sure you'd get a blank stare,
But if you stated it's a 1965-67 Ford color called Arcadian Blue, they can look it right up there.
the whites are another good example of the differing names...Im of the thinking that Corinthian and Wimboldon and whatever name it became later on are all one and the same...best example I see in 61-6 trucks is the dashboard....
Thank you guys for all the info on my truck. It is painted white at the moment and I wanted it back to the original color. I need to see if I can find some pictures of truck with this color and what the interior looks like. First I have to yank the motor out and get it back in running order. Thanks again for all the help.
