Donor Truck vin - help needed
I changing my 69 F350 over to Front disk brakes. The Junk yard has a 79(?) F350. Here is the info from the drivers side door plate: F37SRDCO364. WB:161 COLOR:K TYPE F378 BODY:AB8
TRANS:K AXLE 36J MAX GVWH:10000 1979 DSO 74 (SEATTLE?) I was able to get the entire front suspension, except the junk yard crew removed the calibers and brackets. Can anyone decode the vin, and does anyone have a parts breakdown of the front brakes? Thanks in advance.
Ok, thanks Jefffafa. I guess I'm overly cautious. This is the first time I've done a drum to disk swap. Just trying to get everything in place before I take the drum system off. I'll order new rubber parts for the arms and sway bar next. No rush tho- raining for two days now, rain called for the next 2 or 3 days too.
GaryKip
11-30-2015 02:52 AM
