Code 1316
Old Feb 13, 2010 | 07:16 PM
fixnair's Avatar
fixnair
Code 1316
Got a code P1316 "Injector drive module code detected". Tried to erase it and got a message "Erase Failed". I have also gotten a code something like "low injector pressure" or something like that in the past. Do these codes portel of an impending failure? I haven't been working much and do not need an expense right now. Is this kind of a nuisence thing or do I really need to pay attention to this? I don't want to hurt my treuck either. I make my living with it. Which way do I go?
Old Feb 13, 2010 | 09:29 PM
F350-6's Avatar
F350-6
What symptoms did you get with the codes? What are you using to pull codes? I've never heard of a can't clear codes message.
1316 is often a loose UVCH, so that's something worth checking that won't cost you a dime (but might end up costing you a couple of quarters )
Old Feb 15, 2010 | 11:23 PM
fixnair's Avatar
fixnair
Sorry for the delay in getting b ack Chris. Took a long weekend over on the coast. There are no driveability issues. It runs smooth and strong, no missing and it starts right up. I have a Chraftsman OBD scanner. I don't think the inability to clear the codes is a problem with the truck, more than likely a problem with the tool.
Thanks for the response
Steve
pilgrimbizket
38
Aug 4, 2013 08:46 PM
Macamon
23
Oct 10, 2011 03:17 PM
wtroger
Sep 22, 2011 08:29 PM
orng1
Jul 20, 2008 08:35 PM
PlatinumPSD
Oct 4, 2007 08:09 AM
