white smoke
Old Feb 13, 2010 | 09:48 AM
cricketmowing's Avatar
cricketmowing
white smoke
I have 2004 f-350 6.L with over 100.000 miles.recently notes white smoke coming out of talil pipe really bad. happens cold or hot.notes black deposit on the tail pipe.check for codes no codes.there is a miss while you driving.I would suspect bad injector but I could be wrong.
ANY IDEA?????
Old Feb 13, 2010 | 10:12 AM
bismic's Avatar
bismic
Are you losing coolant? It is common for a leaking EGR cooler to blow white smoke out the exhaust. What is your fuel economy doing?
Old Feb 13, 2010 | 10:16 AM
cricketmowing
I have leakey coolant bottle that I have to replace,has hair line crack.and I just ordered adapter for coolant bottle so I can pressure test the system to see if it has internal leaks.
Old Feb 13, 2010 | 11:26 AM
bismic's Avatar
bismic
The manual states to do a vacuum test. You need some specific equipment to do it. The white smoke is either fuel or coolant. Does it smoke at an idle? If so, what does it smell like? As I said, sometimes your fuel economy will give you a clue. It is always good to have the codes read if you have a way to do that.
Old Feb 13, 2010 | 11:37 AM
cricketmowing
it smells like diesel. smokes at idle than its stop for @ 30-40 seconds than again. I'm using this truck for snow plowing and land scaping and it is hard to figure out mpg.
Old Feb 13, 2010 | 12:19 PM
bismic's Avatar
bismic
Sounds like it is time to focus on which injector(s). Do so quickly, if you dump a lot of fuel in a cylinder it can be bad. It may be worth a trip to the dealership to get the codes read.
Excessive smoke and fuel smell could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings. Also PCM inputs such as MAP or ICP sensors.
Old Feb 13, 2010 | 12:40 PM
steelhead2's Avatar
steelhead2
you could also pull the egr valve and give it a cleaning, and at the same time check for any wetness in the intake or on the valve.if it's wet you'll need to change the egr cooler.
Old Feb 13, 2010 | 04:49 PM
cricketmowing
thank you for tips.I will update post with the fix.
Old Feb 13, 2010 | 06:08 PM
bismic's Avatar
bismic
Here are some links to injector troubleshooting tips:
<TABLE style="WIDTH: 582pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=776 x:str><COLGROUP><COL style="WIDTH: 582pt; mso-width-source: userset; mso-width-alt: 28379" width=776><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: fuchsia; WIDTH: 582pt; HEIGHT: 12.75pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl25 height=17 width=776>Compression Bubble Test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: fuchsia; WIDTH: 582pt; HEIGHT: 12.75pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl26 height=17 width=776>http://www.forddoctorsdts.com/articles/article-08-03.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: fuchsia; WIDTH: 582pt; HEIGHT: 12.75pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl25 height=17 width=776>The old Balloon test</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: fuchsia; WIDTH: 582pt; HEIGHT: 12.75pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl26 height=17 width=776>http://www.forddoctorsdts.com/articles/article-05-03.php</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-BOTTOM: #ece9d8; BORDER-LEFT: #ece9d8; BACKGROUND-COLOR: fuchsia; WIDTH: 582pt; HEIGHT: 12.75pt; BORDER-TOP: #ece9d8; BORDER-RIGHT: #ece9d8" class=xl24 height=17 width=776>Remember to remove the fuel pump relay when doing the balloon test or you will have fuel everywhere.</TD></TR></TBODY></TABLE>
Old Feb 22, 2010 | 05:09 PM
cricketmowing
up date on repair
finally truck is fixed.after @$1600 in parts : oil cooler,egr cooler,filters,oil,coolant,also I replaced oil pan.was leaking oil.and some misc.parts.for the labor I would say @ 40h I did it by my self.
thank you all for tips
yankesfn2
Aug 24, 2012 11:11 PM
roxxiiee1324
1978 - 1996 Big Bronco
Jul 13, 2011 01:17 PM
Bergerson
17
Apr 16, 2008 09:56 PM
weldingfreak
Feb 12, 2006 03:10 PM
kitsapcountychopper
25
Mar 19, 2004 08:11 AM
