Excessive White Smoke
Old Mar 16, 2004 | 07:32 PM
kitsapcountychopper's Avatar
kitsapcountychopper
GOT THE OLD GIRL BACK TOGETHER.IDLES DECENT BUT WHEN I TROTTLE UP WHITE SMOKE POURS OUT THE TAIL PIPE AND IT IS STUMBLING. .ANY IDEAS ?? SMOKES SO BAD LOOKS LIKE ITS ON FIRE
Old Mar 16, 2004 | 07:42 PM
pnose's Avatar
pnose
Does it do that even after its warmed up?
Old Mar 16, 2004 | 07:46 PM
kitsapcountychopper
does it when it is hot .did it before i tore it down to fix a broken lifter and bent push rod.intake valve was not working on number 7.does not seem to smoke at a idle only when i push the trottle down.
Old Mar 16, 2004 | 07:49 PM
pnose's Avatar
pnose
White smoke is usually air in the fuel system.Have you replaced the return lines and o-rings yet?How easy is it starting when hot?
Old Mar 16, 2004 | 07:52 PM
turbo69's Avatar
turbo69
white smoke could also be due to retarded timing
Old Mar 16, 2004 | 07:54 PM
kitsapcountychopper
could this be a problem with bad injectors or the copper washers being bad ??
Old Mar 16, 2004 | 07:56 PM
pnose's Avatar
pnose
If you had the injectors out and re-used the copper seals that could cause a prob as they are a one use item.
kitsapcountychopper
i see no fuel leaks,however i did change the return lines from the injector caps to the filter.
Old Mar 16, 2004 | 07:58 PM
kitsapcountychopper
i never pulled the injectors.idles smooth but when i push the trottle down it runs like it has a miss.i was wondering if a injector could be bad ,either the tip or ?? it stumbles bad
Old Mar 16, 2004 | 07:59 PM
pnose's Avatar
pnose
What about the o-rings and the rubber lines between the injectors.They could be sucking air but not bad enough to leak fuel.
Old Mar 16, 2004 | 08:00 PM
kitsapcountychopper
that would make it smoke like this ?? great bug killer .
Old Mar 16, 2004 | 08:05 PM
pnose's Avatar
pnose
Have you had your timing set since you put the ip on?Air will make it smoke and rough runnin,unfortunatly so will a ip thats on the way out.Are you runnin fuel additives.
Old Mar 16, 2004 | 08:13 PM
kitsapcountychopper
put the same pump on in the same marks,no fuel additives.this was smoking bad before i tore it down for other reasons.compression averages about 410 pounds on all 8 clys now after i fixed the other problems,i tought the smoke before i tore it down was because the intake valve was not opening and fuel was going out the exhaust ,i fixed that problem .but the miss about idle along with the smoke is bad.above a idle
kitsapcountychopper
Old Mar 16, 2004 | 08:14 PM
turbo69's Avatar
turbo69
you really should time it. I had the same problem with my truck after the engine wap. I ended advancing the pump almost to the faqctory stops before I got it to run right. Yes, timing can cause a ton of white smoke and stumbling. The truck is probably quieter than it was before too. Try to advance the pump.
