1978 F-100 Kingpins
1978 F-100 Kingpins
The kingpins need to be replaced on my truck. I am getting ready to order them from LMC and don't know if I should get the ones with metal bushings or the ones with nylon bushings. What do you guys recomend? Also, I figured I would go ahead and do the radius arm bushings and axle pivot bushings while I am at it. I can do the bushings myself no problem, but am going to have somebody else do the kingpins. Would it be cheaper to just take the I-beams to the shop and have the kingpins pressed in, rather than taking the whole truck since i will have the front end dropped for the bushings anyway?
-Nick Good
-Nick Good
And I would recommend taking the whole shebang to a shop to have the old kingpins pressed out. Waaaaaaay easier than heating and using a BFH to try and force them out.
I'll second the use of metal bushings.
After it's all said and done be sure to make it a routine to grease those kingpins regularly.
Josh
Josh
Thanks for the input. I am curious to see what people have paid to get them done. Also, did you guys just drop of the I-beams or the whole truck, because i figured it would be somewhat cheaper if I just took the I-beams to the shop since I would not have to pay them to dissasemble as much.
Thanks, Nick
Thanks, Nick
It would be way cheaper to just take the beams in to have the old pins pressed out.
A machine would just charge normal labor rate to press the pins out, press old bushings, install new bushings and hone.
At at truck or suspension shop you have the disassembly of the entire front end and then whatever they try to do to get the pins out. Some leave everything attached and try to heat the beams to ge the pin to move. Others would take the beams in to another shop and you then get charged DOUBLE.
I had mine done in 2000, I think I paid more for the kingpin kit than I did for the machine shop costs as the work was done in well under an hour.
Josh
Josh
jayro88
11-04-2016 05:45 PM
PRUSue
13
10-27-2016 05:12 PM
hulleywoodworking
10-29-2015 03:05 PM
JJS72XLT
12-02-2012 06:29 PM
