Vibration on 95 F-350
I have a 95' F-350 Powerstroke 5-speed and I am getting excessive
vibration at idle and it gets worse the higher the rpms get, by 2500 rpms
its pretty bad.
I do not know the shape of the clutch and throw-out bearing, but it is a
single mass flywheel.
At this point I am guessing it might be the pressure plate but I dont know for sure.
Any other ideas?
Thanks,
its pretty bad.
Any other ideas?
Thanks,
The flywheel or pressure plate are reasonable to suspect. I think the clutch is too light to cause such a vibration, but I suppose it's possible. I have this issue, too. I did a clutch rebuild last year and a new vibration cropped up. I even had the drive-line balanced by a reputable shop. This was a Luk SM clutch kit and the flywheel and pressure plate are both machined in China . Yes, I ponder their exacting standards.
Is their any difference when you press the clutch in or not? When you are moving or not?
I have a spare set, so I may have them machined (balanced) and swap em out. But I may not get to this project for a little while. My vibrations are not too severe. Just enough to irritate me.
DS
DS
DS
speedworks
01-05-2008 08:45 PM
