wierd vibration
Old Oct 22, 2012 | 08:41 PM
reylings's Avatar
reylings
wierd vibration
I just bought my 04 f350 and it developed a vibration after a crack. ive looked over everything and cant see anything vibrating. it vibrates with the rpms of the motor, i can make it stop by turning the wheels one direction or the other. its really bad when the brakes are on, and when rocking the truck the noise will stop also. im completely confused on what it could be. please help.
Old Oct 23, 2012 | 10:14 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE reylings I guess I am confused, after a crack? When the engine is idling it runs rough?
Old Oct 23, 2012 | 04:31 PM
reylings's Avatar
reylings
no the way it runs has not changed.
Old Oct 23, 2012 | 04:58 PM
bpounds's Avatar
bpounds
Stay away from crack!
Problem solved.
Sorry.
You might want to explain what you meant by crack. But I'm thinking hydro-boost pump.
Old Oct 23, 2012 | 05:01 PM
reylings's Avatar
reylings
idk of any other way to explain it. the truck didnt jolt or anything it just made a crack and went.
Old Oct 23, 2012 | 06:37 PM
samsdad02's Avatar
samsdad02
check your ujoints in the front axle knuckles and the driveshafts
Old Oct 23, 2012 | 07:00 PM
reylings's Avatar
reylings
thanks ill try that.
Old Oct 23, 2012 | 07:05 PM
Maxium4x4's Avatar
Maxium4x4
Is this vibation while driving or sitting? U-Joints if driving like mentioned.
Old Oct 23, 2012 | 07:31 PM
reylings's Avatar
reylings
it occurs during both. sitting and driving. its just more noticeable when sitting still.
Old Oct 23, 2012 | 07:44 PM
samsdad02's Avatar
samsdad02
sitting in park or drive? brakes on in park? sitting in park with brakes on rocking the steering wheel back and forth?
Old Oct 23, 2012 | 08:32 PM
reylings's Avatar
reylings
all of the above. sitting still in park, reverse, neutral, and drive. rocking the steering wheel and rocking the entire truck. but if i turn the steering wheel far enough to both sides the vibrations stop.
Firealmond
15
Dec 1, 2012 12:31 PM
Vankaye
Sep 17, 2005 11:07 AM
mjs
Jun 21, 2005 09:46 AM
jeffbk
Dec 29, 2004 03:54 PM
