OD light blinking, Hard shift, Jerky in reverse.....VSS Sensor???
Old Feb 8, 2010 | 04:52 AM
mxracer3276's Avatar
mxracer3276
Well the title says it. Yesterday i went through a kind of big pile of snow trying to make a turn in a parking lot. After that i noticed the OD light blinking but the truck ran fine and the light goes off a couple minutes later. 2 hours later, i go to get pizza and the light starts blinking again sporatically and the shifts are getting harder to the point where my girl was asking me whats wrong with the truck, why is it doing that. Anyway, wake up this morning to go to work and as i go to back in to my spot, i put it in reverse and hit the gas, the truck hesitates, then will go a little bit, then keep hesitating and so on..... Does this sound like the VSS sensor, or something more serious like the TC or something??? I dont have anyway to read codes, but going to try and get them read at a buddies shop if he has the right scanner.
Old Feb 8, 2010 | 05:45 AM
just another truck's Avatar
just another truck
It is not the VSS, you might want to try and crawl under and blast the electrical plug with some WD-40, check to make sure it hasnt come loose. This is the only thing that I can think of other then a hole in the trans pan and no oil..
Old Feb 8, 2010 | 06:19 AM
mxracer3276
I dont get it though, other threads i have read about the VSS going bad are very similar sypmtoms to mine...
Old Feb 8, 2010 | 06:29 AM
just another truck
I might be wrong Matt, but if I Recall, the VSS will cause the blinking, it may be intermittent, but you added the shifting was getting harder, and I dont recall that as part of the issues.
So, I am going to shut up and pay attention, I dont want to send you down the wrong road here, but again, wouldn't hurt to hit the VSS with WD-40 (the plug).
Old Feb 8, 2010 | 06:34 AM
mxracer3276
Na, not saying you were wrong Pat, and believe me, i more then appreciate any input you have. I just spent the better part of the morning looking at threads about this, and i saw a couple threads on it, one including Brendan, saying that the were experiencing hard shifts and once replaced the VSS the shifts smoothed out.
Here is the thread:
https://www.ford-trucks.com/forums/5...s-the-vss.html
Old Feb 8, 2010 | 06:37 AM
mxracer3276
And i should have added also that the shift really arent banging, the shifts are just noticably "unsmooth"
Old Feb 8, 2010 | 07:10 AM
mxracer3276
Now on the way home, no light, shifted a little smoother, and went in reverse fine, no problems at all. What is going on here....?
Old Feb 8, 2010 | 08:16 AM
mueckster's Avatar
mueckster
While the VSS on the diff may affect shifting, I don't think it would the 'going into reverse' part of the problem. I am leaning toward a possible problem with DTR (digital trans range) sensor on the trans gear shift lever. My symptom chart shows it can cause harsher shifting if misaligned or damaged (affects EPC...shift pressure). I'm not 100% sure, but it could also affect the engagement of reverse because the PCM uses the signal from this sensor to 'read' gear position.
Checking for the codes would be the place to start in where to look for the problem. If you can get them read, we can figure this out.
Old Feb 8, 2010 | 08:20 AM
mxracer3276
Yeah thats what im trying to do, i just have no way to get them read right now. The dealer wants $104.97 just to pull the codes, sorry im not paying that, ya know. So i dont know what to do yet.
Old Feb 8, 2010 | 10:32 AM
mueckster's Avatar
mueckster
Did a little reading. There is no electrical concern shown for a delayed reverse engagement. It is possible that the shift linkage could have gotten knocked slightly out of adjusment. This could cause the applying of reverse to be affected and also throw the DTR sensor out of synch with the valve body. Let us know what codes come up this evening. Hope they point to something minor.
Old Feb 8, 2010 | 03:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Start buying parts. I'd guess the DTR, VSS, OSS, TSS to start. That should have you well over $100. If those don't fix it we can try other things.
Or you could spend some money and find out WHY the OD light is flashing. Then you could fix what's wrong and end up spending less money. Your call.
Old Feb 8, 2010 | 08:20 PM
mxracer3276
Thanks Mark, i was hoping you would chime in soon. Well i got in touch with a buddy of mine out in Utah who used to own a shop near my house. He called his old shop up and told them i need the scanner, they told me to come in tomorrow and we will hook it up to the Snap-On scanner. So then we will at the least have an idea of whats going on.
longboy
Apr 6, 2017 10:08 PM
milehi_350
Mar 28, 2017 01:36 PM
CASHER0010
Mar 27, 2015 03:59 AM
dinebito
1978 - 1996 Big Bronco
Jul 25, 2011 11:41 AM
gametime2387
Feb 4, 2010 10:17 AM
