HELP!!!
Old Feb 7, 2010 | 10:13 PM
davewave649's Avatar
davewave649
HELP!!!
I know that the engine on my truck needs rebuilt, but now i think it needs it asap, heres whats going on: I did an oil change the other day and used high milage oil, well when i was driving it yesterday i noticed a significant amount of smoke coming out from under the hood and when i opened the hood i found oil dripping out of one of the breathers, does anyone know what would make this much oil go up into the breather?
Old Feb 7, 2010 | 10:20 PM
1965f100factory4x4's Avatar
1965f100factory4x4
i know this sounds dumb but how bad was it smoking and how much oil did you put in?
Old Feb 7, 2010 | 10:27 PM
garbz2's Avatar
garbz2
What Engine?
FE and Y blocks will pour oil out of the valve covers if the oil return holes in the head are blocked as the oil provided to the rockers cannot return to the pan.
I6 takes a bit more to get oil out of.
Garbz
davewave649
The smoke was being caused by the oil dripping from the breather on to the exhaust manifold. But i put in 8 quarts which is how much my maintenance manual says to put in a 302 (my motor was swapped by the PO) but i might have overfilled it, would that cause these issues?
Old Feb 7, 2010 | 10:37 PM
Bill W's Avatar
Bill W
Yes! 3 quarts too many. I dont know of any 302 that takes more than 5 quarts.
Old Feb 7, 2010 | 10:38 PM
garbz2's Avatar
garbz2
8 Quarts holy ****skie! Stock small blocks with stock pans take 5 and that includes the one in the filter. You are about double capicity.
Did you look at the 302HD, those take 8 quarts plus one in the filter and are no way confused with a 302 windsor.....
302HDs are found in C700 and F700 and larger trucks.
Garbz
Old Feb 7, 2010 | 10:48 PM
davewave649
crap, ok thanks for the help. that would explain alot, bid mistake on my part. thanx for the help
Old Feb 7, 2010 | 10:55 PM
garbz2's Avatar
garbz2
What book did you look in for the info?
Garbz
Old Feb 7, 2010 | 10:59 PM
davewave649
The manual i have is a 1962-1963 shop manual, its a repro of the original ford ones. and i didnt see that it was talking about the hd 302s as opposed to the 302w like what i have and i assumed that all 302s were the same. big mistake on my part
Old Feb 7, 2010 | 11:37 PM
garbz2's Avatar
garbz2
Yep, will get you every time. I double checked my 63 spec book and the 61 Shop manual to check if that's what you may have done.
You probably did not do any internal hydraulic damage but be prepared for all the gaskets to leak. This is typical when overfilled as it pressurized the crankcase.
Garbz
Old Feb 7, 2010 | 11:51 PM
davewave649
ok thanx for the heads up and now i know for next time. I happy that this will be an easy fix, i thought i was gonna have to rebuild y engine now which wouldve forced me to pass up a 32 3 window im looking at
Old Feb 7, 2010 | 11:53 PM
starmilt's Avatar
starmilt
LOL how far above the full mark on the dipstick was it.
Old Feb 8, 2010 | 12:40 AM
1965f100factory4x4
wow.... im suprized i got it on the first go... but hey evrybody makes mistakes
Old Feb 8, 2010 | 01:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 302 (and 332) were used in 1957/63 BIG trucks, and were based off the 1952/55 Lincoln Y Block.
Y Block = the distributor is behind the carburetor.
Old Feb 8, 2010 | 02:03 PM
davewave649
The dipstick is reading twice as high as the full mark, last time i refill it without checkin the dipstick as i go
arrowheadfred
Jan 27, 2011 07:03 PM
Briansford
Dec 11, 2004 11:52 AM
87black150
Jul 31, 2003 06:05 PM
tapenick
Feb 17, 2003 09:23 PM
mikeeep
Jan 17, 2003 11:32 AM
