Engine blown, what do you think?
Old Feb 6, 2010 | 04:54 PM
WhiskeyRider's Avatar
WhiskeyRider
Im looking for opinions based off of the few features that were scene when this happened.
I was driving at about 50-55 mph, and I noticed the engine started to feel pretty sluggish. WOT and still very sluggish. Then the whole front end started shaking pretty bad and I looked in the rear view mirror and saw a huge cloud of white smoke. I pulled over and took a look, and there was white smoke coming out of the oil breather and from the back of the engine between the intake manifold and block. You have never heard an engine run rougher than this bad boy was. I was actually scared to get near it for a few moments thinking the crankshaft was going to come flying at me haha.
Im aware of many possibilites however before I start tearing into her I wanted some second opinions from trusted voices.
Thanks.
Old Feb 6, 2010 | 05:27 PM
DeepRoots's Avatar
DeepRoots
not knowing what engine it is.....
tho it sounds alot like the engine ingested some coolant.
Old Feb 6, 2010 | 05:32 PM
johnboy427's Avatar
johnboy427
Rod through the block. Thats my guess, they make all sorts of god awful noise and smoke until what is left of the rod comes free of the crank, they also don't run so good. Was it making a lot of mechanical noise (metal stuff smacking into other metal stuff)?
-Johnboy
Old Feb 6, 2010 | 05:48 PM
WhiskeyRider
its a 360.
Not a lot of metal banging metal, i'm leaning towards a blown head gasket though, because I tried cranking it over after. it budged but then stopped, might have hydrolocked that cylinder
Old Feb 6, 2010 | 05:51 PM
johnboy427's Avatar
johnboy427
Probably not a rod if no banging, i figured there would be a lot of banging since you said you were afraid to get close.
-Johnboy
Old Feb 6, 2010 | 05:52 PM
starmilt's Avatar
starmilt
Running sluggish then started smoking and now locked sounds like it overheated and was driven as far as it was going to go.
Old Feb 6, 2010 | 05:55 PM
WhiskeyRider
I cant even begin to describe how this sounded.. maybe its just a blown head gasket
Old Feb 6, 2010 | 06:03 PM
1974SuperCabF250's Avatar
1974SuperCabF250
I agree. Before you assume 'the engine's blown' find out what the hell actualy happened...
Old Feb 6, 2010 | 06:11 PM
WhiskeyRider
As I stated in the beginning, i was trying to collect ideas before tearing into it. Sorry for any confusion.
Old Feb 6, 2010 | 06:28 PM
RVDan's Avatar
RVDan
Sounds like a seized up connecting rod. I've had the same symptoms before. Engine lost power, required first gear and full throttle to keep moving. Then it gained power again after the rod bearing finally spun. Till another rod started to seize up due to the lost oil pressure from the spun bearing.
Then a whole lot of frightening noise until it tossed a rod out the side of the block.
Pull the oil pan off and have a look.
Old Feb 6, 2010 | 09:35 PM
DeepRoots's Avatar
DeepRoots
I dunno about that.... I was standing next to a Detroit 16v149 on a tugboat trying to assess why it was smoking out of the exhaust when it dumped all the coolant into the airbox (cracked block) and promptly trashed 13 of the 16 cylinders. I assure you that was an interesting sound.
As the last poster said, start to tear into it and all shall be revealed! I'm leaning towards overheated + cracked head = locked up engine.
Missing coolant, milky oil, etc would lend itself to this.
Won't really know till you look.
Best of luck,
Drew
Old Feb 6, 2010 | 10:58 PM
wyckedcombo17's Avatar
wyckedcombo17
did that result in spontaneous defecation into your undergarments?
and yeah, I agree with everyone else. Check to see if its not hyrdrolocked or a cracked head before you order a new crate.
Old Feb 6, 2010 | 11:44 PM
WhiskeyRider
Ill start tomorrow digging in, there was some pretty bad noise coming out of the valve train too.
Crate engine, na. Im lookin for a 4BT cummins to put in this bad boy if this is shot, but well see
Old Feb 7, 2010 | 08:01 AM
SNSTER's Avatar
SNSTER
well if you end up just wanting to replace I have a 360 in a truck I bought for the body. runs good. drove it over 300 miles home. Just a thought to take a cheaper way out
Old Feb 7, 2010 | 11:19 AM
wdfp's Avatar
wdfp
I have one sitting here with a 460 someone drove a little too far, one cylinder has a neat little 3" crack running down it now, once they get that hot figure on replacing and hope for the best
powerstroked love
Jan 21, 2014 01:13 AM
rockstarf150
1997 - 2003 F150
Jul 9, 2012 10:53 PM
myred
Aug 23, 2011 01:32 AM
sick04
Jan 20, 2010 07:13 PM
TJM70
1997 - 2003 F150
Jan 17, 2007 07:23 PM
