lacking power until warm.
Old Jan 19, 2010 | 02:20 AM
sick04's Avatar
sick04
when i start my truck it will sometimes blow white smoke and wont build power until it starts to warm up. im not an expert on the 6.0 so if the sluggish start is normal thats fine but im pretty sure the white smoke isent so any help would be great thanks!
Old Jan 19, 2010 | 05:25 AM
foul1's Avatar
foul1
Your gonna get asked how many miles, mods, and repairs done to it before you get a whole lot of usefull information.
Old Jan 19, 2010 | 07:19 AM
bismic's Avatar
bismic
How many miles?
Any mods?
Any recent repairs?
Also ....
What year?
Is it just a little white smoke at start up or a lot, or a lot all the time?
Can you have someone start the truck while you see if the white smoke has a sweet smell or a fuel smell?
Have you ever pulled your EGR valve?
We need a lot more info to troubleshoot!!
Old Jan 19, 2010 | 07:31 AM
going up 2!'s Avatar
going up 2!
could it be the FICM?im new to 6.0 also but i had to replace mine after similar issue.
Old Jan 19, 2010 | 08:52 AM
Lubbockguy1979's Avatar
Lubbockguy1979
Also the oil can be the issue. 5w40 is recommended. The 15w40 most of us use in the summer can be pretty thick on a cold morning.
Old Jan 19, 2010 | 04:09 PM
sick04's Avatar
sick04
it is an 2004 and has intake exhaust and has 190,000 miles and had tha injector pump replaced about 4 months ago. and tha smoke it dumps alot for about 5 minutes then stops after the truck starts to get warm and sometimes it dosent smoke at all
Old Jan 19, 2010 | 06:44 PM
steelhead2's Avatar
steelhead2
pull your egr valve out and check for wetness in the intake.if you see wetness the egr cooler's a goner.when you try to start it first thing does it sound like it's trying to compress water?.if you coolers leaking bad enough it'll fill #7 with water.....i know the sound well.......
Old Jan 19, 2010 | 07:40 PM
lakewood's Avatar
lakewood
white smoke is typical on a cold start-up, 5 minutes worth, might be a little much, when the engine is cold try not to go above 2k rpms, and your turbo will be at higher psi when the engine is cold, i would also run rotella t synthetic or something comparable. with it white smoking that much take it to the dealer and see if it's throwing codes.
Old Jan 19, 2010 | 10:03 PM
mohle's Avatar
mohle
My first question would be is how cold is cold start? I do believe that the electronics won't allow full power until the vehicle has warmed up. In regards to the EGR valve being wet, don't assume the worst, but be prepared. Under really cold conditions condensation can build up in the EGR system. Around here a lot of trucks are running winter fronts that block out the radiator. If you try starting a cold truck here at -20C don't expect to drive it away right away. Even after a five minute warm up, the trucks don't really care to move quickly and aren't very responsive. Probably a good idea to clean the EGR valve though.
Old Jan 20, 2010 | 12:46 AM
sick04's Avatar
sick04
well about the egr i know its possiable to delete it how much does this process usually run i know the kit is around 500 bucks.
Old Jan 20, 2010 | 09:08 AM
hott-rodd's Avatar
hott-rodd
Some very good kits around $300.
Old Jan 20, 2010 | 10:36 AM
going up 2!
if u go ahead and do the delete kit,can u and how difficult to re install the egr?
Old Jan 20, 2010 | 03:14 PM
embry1123's Avatar
embry1123
From what I've learned here and from looking around at the delete kits, you could perform the delete of the cooler and replace the up pipe so that no exaust is going to the EGR any longer, and then just leave the EGR in it's original position. However, as I believe BISMIC said, you are likely to still get an EGR code unless you turn it off using a tuner.
Old Jan 20, 2010 | 07:03 PM
sick04's Avatar
sick04
well how much is install on an egr delete kit cause im about to get a good amount of cash and just do that.
Old Jan 20, 2010 | 07:13 PM
steelhead2's Avatar
steelhead2
i would make sure the cooler's leaking before you spend a dime.
Pridnjoy
Oct 27, 2013 04:00 PM
Triplespeed
Aug 24, 2013 06:42 PM
Vanzal15
Feb 26, 2013 01:08 PM
URDADDY
Jan 27, 2012 09:04 PM
deckpros
15
Dec 18, 2009 10:28 AM
