Hard to put a cabover camper on a truck with stacks. I do like the way they breath better when done properly but losing any part of the pickup bed is just not an option for some of us.
i just took a piece of flat steel and cut a hole in it then welded a piece of pipe to each side on with the diameter of the factory exhaust so i can slide the flex-pipe between it and the actual exhaust pipe and ran that through the bed and on the other side i welded a piece the size of the inside of the stack and then welded the stack to that so it has support other than just the thin wall of the pipe and then i put 4 bolts through the bed to mount the plate.so to remove the stack i take one exhaust clamp loose and 4 bolts and the whole deal slide right outta the bed.it takes less than 5 min. i did it this way in hopes of putting a camper on it soon
ok after reading this thread just in case you guys had any doubts haha on my name in this site its not cause i actually roll coal all the time or think its cool i just liked the name and like a few others were sayin earlier in here itll puff once in a while at shifts or pullin my gooseneck loaded up hill
