1.0 ar housing?
Old Feb 6, 2010 | 01:42 AM
hedhntr's Avatar
hedhntr
1.0 ar housing?
Been thinking of this for awhile but thought i would ask here for opinions. based on the truck in my sig adding a bigger housing what should i expect? seems like egt would go up and more turbo lag at low speeds. any more pros or cons. Thanks
Old Feb 6, 2010 | 06:11 AM
Pocket's Avatar
Pocket
With a chip, you probably won't notice much difference in lag.
EGT's on the bottom end will only change slightly. Top end will lower a bit.
Old Feb 6, 2010 | 07:06 AM
beanhead6D5's Avatar
beanhead6D5
I like mine for the mid-range pulling power.EGT are a bit lower,maybe 50*.Its a nice upgrade on a stock eng.
Old Feb 6, 2010 | 08:48 AM
sflem849's Avatar
sflem849
FYI - Spdmoto (? One of the guys from the 7.3 forum...) has one in the classifieds for $200. Maybe that is why you are asking
sflem849's Avatar
sflem849
Will it change your surge point at all?
Old Feb 6, 2010 | 09:43 AM
mueckster's Avatar
mueckster
It should help slightly. I already had the ATs compressor housing when did the 1.0 turbine housing, so surge was already gone. The two housings do make a great combo. Lowered my EGTs and gives a bit more whistle upon acceleration with the foil delete mod. I loved it until I did the swap to the 38R.
Old Feb 6, 2010 | 11:35 AM
spdmpo's Avatar
spdmpo
I have one in the classifieds if you are interested. $200, free shipping, and pedestal o-rings included. Good deal...
Old Feb 6, 2010 | 11:39 AM
Izzy351's Avatar
Izzy351
Why aren't you using it, Keith? It would complement your combo nicely.
Old Feb 6, 2010 | 12:00 PM
spdmpo's Avatar
spdmpo
I'm lazy, don't want to take the turbo off again. I don't really drive hard, haven't felt the need. After being live tuned I don't see high EGTs. Mostly though, I want to use the money to buy AE. If no one buys it before RRE, I'll take it with me and put it on there if Nick will help me get the up pipe loose.
Old Feb 6, 2010 | 01:05 PM
sflem849's Avatar
sflem849
That's the one I was talking about
Laziness is the only thing stopping me as well. I also have a tendency to create/find additional problems when I start modding. My truck has worked "fine" for over a year so I hate to start modding again. I am sure my up pipes leak. How much additional work is it to change them when I am in there putting the housing on?
Old Feb 6, 2010 | 01:28 PM
Izzy351's Avatar
Izzy351
Turbo comes out pretty easy, once you've already had it out. I can pull mine in <30 mins now (with air tools).
Old Feb 6, 2010 | 02:09 PM
ron's power stroke's Avatar
ron's power stroke
i may have one for sale too... i want a little more then $200 though..
it comes with a EBPV deleted outlet.. a WW and a stock turbo..the turbo was brand new from Ford...not a rebuilt..it has 4000 miles on it right now..i ran it with my sticks i have now..no surge and i could hit 35 LB of boost with no problems..(i dont recommend going over 30)..EGT's where good but much better with the 38R...my G/F and family bought me the 38R for christmas,,this stock turbo went from the truck to the bag then boxed and taped in the 38R box and kept in the house away from moisture...
Old Feb 6, 2010 | 03:29 PM
spdmpo's Avatar
spdmpo
Well that would be the time to do both of those things. The turbo needs to come out to do the exhaust housing, and it will be much easier to do the up pipes with the turbo out. I'm certainly not trying to pressure this sale, but I will say that I would be doing both at the same time. If I end up doing this at RRE, I'll be doing the up-pipes too so I don't have to go back again. Otherwise, I'll do neither.
I'm pretty much angry with myself for not doing this and the up-pipes last year at RRE while we had it out to change the turbo pedestal o-rings.
Garden Spyder
Kansas Chapter
87
Jul 16, 2013 07:51 AM
bengerman
Nov 11, 2012 04:52 PM
cowmilker08
17
Dec 19, 2011 12:03 PM
Snowbunny
Washington Chapter
20
Apr 2, 2011 09:35 PM
Skip1970
69
Jan 21, 2011 01:32 AM
