203* stat
Old Feb 10, 2010 | 09:16 PM
  #61
parkland's Avatar
parkland
Originally Posted by ernesteugene
I was going to that analysis on my turbo thread ...but due to a resounding lack of interest that thread was put on the back burner ...after I get caught up on my engine-wear thread I'll do the with/without IC analysis!
I'm interested....
What about me?
Screw the engine wear thread, too many variables and opinions to make headway anyways.
Old Feb 10, 2010 | 09:45 PM
  #62
driximus's Avatar
driximus
Originally Posted by clux
Everything I've ever seen from Ford says 235 for the auto, 250 for the manual transmission. But I guess Ford's probably wrong about that too.
Sticker on my engine says 250hp im pretty sure they didnt botch the sticker.
Old Feb 10, 2010 | 09:49 PM
  #63
clux's Avatar
clux
That is correct, they increased the horsepower in 2001MY, which I clearly stated in post #31, so I'm pretty sure they didn't botch the sticker either.
My 2000 sticker says 235.
On edit: I take that back. Apparently they did botch the sticker, at least according to dieselmann's site:
"In 1997 the horsepower was increased to 225 and the torque was increased to 480 ft/lbs.
Early 99 valve cover stickers were incorrect showing 250 HP. The engine was actually rated at 235 HP with all accessories installed.
The engines did develop 250 HP and 505 ft/lbs torque for automatic transmission and 275 HP and 520 ft/lbs torque for manual transmission in October 2000.
Engines with automatic transmissions were increased to 525 ft/lbs torque after January 02."
PowerStroke Horsepower and Torque
Old Feb 10, 2010 | 10:01 PM
  #64
driximus's Avatar
driximus
That is correct, they increased the horsepower in 2001, which I clearly stated in post #31, so I'm pretty sure they didn't botch the sticker either.
I take it back as well they did botch the sticker LOL
Old Feb 10, 2010 | 10:03 PM
  #65
parkland's Avatar
parkland
https://www.ford-trucks.com/forums/9...e-concept.html
For anyone interested in me blowing more hot air.
Old Feb 10, 2010 | 10:30 PM
  #66
DocB's Avatar
DocB
I'm running a 203* thermostat.
My housing was getting rusty and needed changing so I did them at the same time.
My research at that time showed that the 203* put the engine into a more ideal operating temp and did not at all effect the longevity. Sources included IH, multiple engine builders, multple Ford diesel mechanics and other diesel mechanics. So I went with it.
I do not have any hard data to prove one way or the other.
I did not know any Ford engineers at the time, but I will inquire now as this subject has got me to thinking.
The answer to the question as to why OEM uses a 195* Tstat was an emphatic emmisions only issue.
I always thought it was silly to burn more fuel to emit less pollution, read short term at the tail pipe.
BTW-I get 21.8 MPG and that's with worn tires. The new ones added about an inch in height so we'll see if we can break the 22 mark this summer.
Show me hard data and I'll switch it out.
Old Feb 11, 2010 | 05:32 PM
  #67
Supercab's Avatar
Supercab
Anybody contacted Bob at Dieselsite to let him know about this descussion?
I'd be curious as to HIS take now some years after he sold the 203s to lots of us.
Old Feb 11, 2010 | 05:43 PM
  #68
Action4478's Avatar
Action4478
...Done......
Old Feb 12, 2010 | 12:23 AM
  #69
DIESELSITE's Avatar
DIESELSITE
Former Vendor
To start: A thermostat regulates MINIMUM operating temperatures. A Radiator regulates MAXIMUM operating temperatures.
and by using a 203*F stat you also give up a significant amount of coolant reserve heat capacity that might come in handy when towing long grades in the summer!
If you have to rely on reserve, God help you if the hill is too long. That's like saying we need to rely on the battery reserve to keep our lights on.
Will switching to a 203* stat guarantee that the temperature of the upper portion of the cylinder liner will never increase by more than 8*F?
A thermostat regulates MINIMUM operating temperatures. A Radiator regulates MAXIMUM operating temperatures. An F550 runs the SAME temperature pulling his 36’ tow hauler with a 192 and a 203. However, when the same truck is empty, he willl run hotter with the 203 than the 192, IOWs, he will run closer to his loaded temperatures.
It’s really that simple. There have got to be 3 million 444E/PSDs running around this country with 203 thermostats in them, whether from the factory, or from Dieselsite. There’s nothing to be scared of, nothing to be confused about, and posts about the thermostat causing overheating are downright false.
So those 94, 95, and 96 powerstrokes with no intercooler, a smaller radiator, and the 203* ought to start dropping like flies any day now, right?
And all those International trucks that do WAAAAY more real work than most all of us.
Originally Posted by CSIPSD
Pulled my 203 stat and threw it in the trash... it was junk.
How did it not perform? One of my best selling products. I get one to two calls a year having an issue with it not closing. I send them a new one and never hear back. There are tens of thousand of our 203 thermostats out there. I run it in all of my 7.3s and have for longer than anyone on these boards, since I ran it in my own truck for testing before I started selling them. Has anyone heard of any of these terrible theoretical conclusions becoming a reality? I certainly haven't, or I wouldn't be selling it. If I had a problem with any item, it wouldn't be on my site.
...so I'd like to see your analysis that using a 203*F stat won't shorten the engine's like expectancy.
Already been done. 444E and OBS trucks. Now show us analysis that using a 203*F stat WILL shorten the engine's life expectancy.
Here's the engineer's paper concerning and applied to this exact engine. This is not theory. He used the 203 thermostat for the research: https://www.dieselsite.com/pdffiles/...nginetemps.pdf
And for those that think they have to take the thermostat out before the weather warms up.
Does that make sense to anyone? Dig your thermostat out of the garbage and call the manufacturer if you have any questions. Dieselsite has always sold proven items.
Recent article in 8-Lug Mag. https://www.dieselsite.com/pdffiles/...0dec098lug.pdf
Here's a link to one of my best selling products year after year after year.... https://www.dieselsite.com/index.asp...ROD&ProdID=186
I feel so bad when people get confused reading these boards. They are on here looking for help, and so many don't know what to believe or not to believe. I try to put as much information on my website as I can. You can always look there for information on my products. You can also be sure that I would not sell something that would hurt your truck. I still have and always will have my 1st Powerstroke and know first hand how much your truck means to you.
Bob
Old Feb 12, 2010 | 02:21 AM
  #70
lostmybeer's Avatar
lostmybeer
Have a nice Beer!!!
Thank You Bob
Old Feb 12, 2010 | 02:29 AM
  #71
twags6's Avatar
twags6
Thanks Bob! I'm putting your t-stat in after my next oil change. My plan is to have 3 UOA's on the factory t-stat and 3 on your t-stat. The factory one is on its way out and doesn't close completely (engine never gets up to full temp even in the 50's).
Old Feb 12, 2010 | 04:37 AM
  #72
Supercab's Avatar
Supercab
Yes, Thanks Bob!! I for one have faith in you and your product!! also wanted to say that the great coolant filter setup you sold me has been mistaken for a factory install its so nice!
Old Feb 12, 2010 | 06:03 AM
  #73
bfife's Avatar
bfife
still plays with trucks
Thanks Bob! I've always maintained exactly what you said. Tstat only controls how fast the engine warms up not how hot it gets. I've run the 203 in both my PSD's and you know how hard I work mine. just a little truck and 5th wheel.
Barney
Old Feb 12, 2010 | 07:34 AM
  #74
clux's Avatar
clux
***************crickets********************
Old Feb 12, 2010 | 07:45 AM
  #75
MADVAN's Avatar
MADVAN
On average a full closed t-stat, "after it has opened" is 15*F (average).
203* is about 188*
192/195* is about 177*/180*
Closing temp is as important as opening temp.
A t-stat is a throttle valve for the coolant.
Bill
