203* stat
Old Feb 4, 2010 | 01:07 PM
Action4478's Avatar
Action4478
..."To avoid scuffing of the ring and liner typical TRR temperatures in diesel engines are kept near 200*C by circulating coolant through the cylinder head. Tests conducted at 260*C have shown that the rings and liners experience wear at least 100 times greater than at conventional TRR temperatures."...
Did you mean Fahrenheit ? 200 C is 392 F, or maybe you aren't talking coolant temp....
Old Feb 4, 2010 | 01:10 PM
pwrtrip's Avatar
pwrtrip
Some good info guys
Old Feb 4, 2010 | 01:22 PM
cavitation's Avatar
cavitation
Originally Posted by ernesteugene
Most emphatically yes it does ...and by using a 203*F stat you also give up a significant amount of coolant reserve heat capacity that might come in handy when towing long grades in the summer! Here's a quote from a paper I'll be discussing in detail on my "wear and tear" thread that reports measurements of piston ring and cylinder liner wear...
...and TRR means... Top Ring Reversal ...which I've already discussed some in that thread and I'll be covering it in more detail in my next installment!
How can I get a copy of the next installment and when is that coming out?
Old Feb 6, 2010 | 04:41 PM
ernesteugene's Avatar
ernesteugene
I just gave a quote from a reference paper ...if I'd written that paper I would've used Fahrenheit ...but then my paper wouldn't have been published because all scientific papers must now use SI units of measure!
The temperature in question is the temperature of the upper portion of the cylinder liner within an inch or so of TDC ...but this temperature is related to the coolant temperature in the head and block in that region.
The point is that according to the test data quoted increasing the ring and liner temperatures by 60*C near TDC ...which is an increase of 108*F ...increased the rate of wear by at least 100 times! So what's the mechanism to account for this seemingly disproportionate increase in wear rate for increasing temperature?
If the temperature of the upper portion of the cylinder liner increases by only 8*F ...which is the difference between a 203* stat and the OEM 195*F stat ...how much additional wear rate is incurred? Will switching to a 203* stat guarantee that the temperature of the upper portion of the cylinder liner will never increase by more than 8*F?
Well if you subscribe to the thread you'll be one of the first to know when new installments are added!
Old Feb 6, 2010 | 04:49 PM
schlepprock250's Avatar
schlepprock250
Subscribing....
Old Feb 6, 2010 | 05:05 PM
driximus's Avatar
driximus
I had heard some bad scooby stuff about the 203 stat some time ago. I decided to stick with the stocker. When I heard this a couple years ago there were alot of Neigh sayers.
big poppa's Avatar
big poppa
Subscribing also, I've been told by numerous folks here to switchout my 203* and when the weather gets a little warmer I will. Also, Ford just came out with, not to long ago a new stock 192* temp. stat. I wonder whats the story on that, maybe Gene can enlighten us...
Old Feb 6, 2010 | 06:54 PM
HD Rider's Avatar
HD Rider
Subscribing
Old Feb 6, 2010 | 06:55 PM
MADVAN's Avatar
MADVAN
60*C =140*f
Increasing by 60*C (140*F) is from what as a baseline temp?
Most use a baseline of 200*F coolant with 235*F oil for testing.
Bill
Old Feb 6, 2010 | 08:01 PM
clux's Avatar
clux
So those 94, 95, and 96 powerstrokes with no intercooler, a smaller radiator, and the 203* ought to start dropping like flies any day now, right?
Old Feb 6, 2010 | 09:51 PM
twags6's Avatar
twags6
Every time this question comes up I always ask what the International version of the T444E uses. Do they have the 203 degree or something lower? Will going from Ford's stock temp of 195 down to a 192 lower fuel mileage?
Old Feb 6, 2010 | 10:27 PM
makomaker's Avatar
makomaker
Proud member of the IIABDFI club.
Old Feb 7, 2010 | 03:24 PM
  #28
trackspeeder's Avatar
trackspeeder
The binder version of the T444E uses a 203 degree stat.
Old Feb 7, 2010 | 03:44 PM
  #29
ernesteugene
As I recall my E99 came with a 192*F stat ...and when I had to replace my water pump the only replacement stat available from Ford was a 195*F stat ...and the only upper radiator hose available was the one that went through the center of the serpentine belt!
Originally Posted by MADVAN
60*C =140*f
Bill
I think you need to recheck you're "math" or your "logic" or both ...because as I "correctly" stated a "60*C increase" in temperature is in fact a "108*F increase" in temperature!
As I also previously stated ...the temperature in question is the TRR temperature of the upper portion of the cylinder liner within an inch or so of TDC ...not the coolant temperature!
So the baseline "TRR temperature" was ...200*C=392*F ...and the elevated "TRR temperature" that was tested for increased wear rate was ...260*C=500*F ...and the difference between the baseline and the elevated temperature was ...500*F-392*F=108*F!
Due to their lower FWHP those OBS engines rejected much less heat into their coolant compared to a late 99.5 truck! The graph below compares the 97 OBS truck to my E99 235 FWHP truck ...and a 99.5 auto is rated for 250 FWHP and the manual for 275 FWHP! ...and just because some of the OBS trucks haven't worn out yet doesn't dispute the "scientific fact" that higher temperatures cause higher wear rates!
..."The International engine that started it all was the 6.9 IDI. The indirect injection 6.9 was simple in design, naturally aspirated, made 170 hp @ 3300 RPM, and 315 lb-ft of torque @ 1400 RPM. The 6.9 was released in 1983 and gained instant popularity. So much in fact, that Ford had to ask International to increase production of the engines, a move that produced a great stream of revenue for both companies. Sometime in 1987, the bore of the 6.9 was increased from 4.00 in to 4.11 inches, and the 7.3 IDI was born. It was in 1994 that the 7.3 IDI became a direct injected, turbocharged diesel and proudly named, the Power Stroke"...
Old Feb 7, 2010 | 03:56 PM
  #30
ernesteugene
By not having an intercooler ...which blocks and heats the airflow going to the radiator on a 99.5 truck ...the OBS truck was better configured for running cooler!
