king pins
Old Jan 31, 2010 | 08:48 PM
Big Daddy T's Avatar
Big Daddy T
king pins
I have just replaced the rear leaf springs and shocks and am in the process of doing the front and replacing i beam and radius rod bushings. I acquired a set of spindles and disc brakes from a friend for notta off of a 77 1/2 ton 2wd. what king pin do i need to use to install these spindles on my 66 i beams and what proportioning valve do i use. also how many psi residual does that valve and master cyl keep on the brakes. i also need to know which master cylinder to use. i can make the linkage work if needed. later i intend to do discs on the back also. thanks for any input you guys have!
Old Feb 1, 2010 | 09:22 PM
Big Daddy T
Help im dyin here!
Old Feb 2, 2010 | 08:41 AM
jmf66's Avatar
jmf66
Short answer... either one will work if you are using new bushings and having them reamed to size. I swapped '78 spindles onto '66 I-Beams and used the '66 kingpins with no problems. However, I believe I could (maybe should) have used the '78 kinpins. The '78 pins are 1/8" longer and .0001 inch larger.
I think about any mid-seventies 2wd proportioning valve and m/c would work. You have to pay attention to the pedal ratio for the booster (whole 'nuther subject). If buying new, get the '77 stuff... easy to remember for replacement parts.
Old Feb 2, 2010 | 03:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
D5TZ3111A .. King Pin Kit / Obsolete
Fits: 1975/79 F100/150 2WD.
D5TZ2B257B .. Brake Differential Proportioning Valve / Use w/front disc brakes / Obsolete
Marked: D5TA-2B524-FA or -FB
Fits: 1975/79 F100/150 2WD / 1976/79 F100/150 4WD.
Fits: 1975/79 F250 2WD 6200 lb. GVW w/single piston caliper disc brakes.
Fits: 1976/79 F250 4WD / 1979 F350 4WD.
Fits: 1975/83 E150 / 1979/83 E100 (E = Econoline).
Fits: 1976/79 Bronco.
Old Feb 2, 2010 | 06:17 PM
Bill W's Avatar
Bill W
Stick with the same year as your Ibeams... if they are 66 then get 66 king pins, if 77 then get 77 king pins
Old Feb 3, 2010 | 03:18 AM
NumberDummy
Originally Posted by Bill W
Stick with the same year as your I-beams... if they are 66 then get 66 king pins, if 77 then get 77 king pins
Since the spindles are from a 1975/79, the king pins are longer than what was used 1966/74.
Wouldn't it be better to use the 1975/79 king pins?
Old Feb 3, 2010 | 07:00 AM
Bill W's Avatar
Bill W
It all depends on what year I Beams you are using..... they have to match the I beams because of where the pinch bolt is located. the spindles do not mater when doing the swap, the pin size is the same.
so yes, BigDaddy needs the 75/79 king pin set if he is using 77 beams.
Old Feb 3, 2010 | 05:38 PM
Big Daddy T
great info guys thanks! ive got the 77 king pin set and they are going to fit nicely. i dont intend to use power brakes for the time being so a booster is not needed just a m/c to fit on the firewall. i can fabricate the link if need be. not sure where to find the osolete proportioning valve though and do i need to do anything about the shorter steering stop on the 77 spindles or does the gear actually let it turn that far without problems? thanks for all your help!
Old Feb 3, 2010 | 05:43 PM
Big Daddy T
oh one other thing the 66 king pin set had the exact same location of the pinch bolt only a litle longe to match the spindles. thanks!
Old Feb 3, 2010 | 06:30 PM
Bill W's Avatar
Bill W
here is a aftermarket one, a bit much on the price. just a last resort if you can not locate one in a junk yard.
Adjustable Proportioning Blocks With Brake Light Switch
Old Feb 4, 2010 | 04:43 AM
NumberDummy
The so-called brake light switch is actually: C8AZ2B264A .. Low Brake Fluid Warning Light Switch.
1967 and later vehicles w/a dual master cylinder have a warning light on the dash that is activated by this plastic switch (screws into the valve) when the brake fluid runs low.
It's not used prior to 1966, so just leave it in place.
Old Feb 6, 2010 | 08:42 PM
Big Daddy T
reat thanks!
troymn
Feb 2, 2015 07:57 AM
1970f100guy
Apr 25, 2014 07:20 PM
Mbellon
Mar 9, 2014 09:48 PM
1965GTFB
Jul 10, 2013 04:58 PM
kdl98
Apr 8, 2002 09:00 PM
