I Beams
Old Feb 1, 2015 | 06:36 PM
troymn's Avatar
troymn
I Beams
Hi Guys. I Have a 66 f100 that I am replacing king pins on. After I got the spindles off the one side the king pin fall threw the I beam without much effort.
I have a 68 f250 2wd camper special parts truck with disk brakes on. My question are the I beams the same as my f100? Thanks again guys!
Old Feb 1, 2015 | 07:30 PM
banjopicker66's Avatar
banjopicker66
If the new king pins do not wobble in the I-beam, or wiggle around as they slip through, then they are fine. They are supposed to slide in and out - but not be sloppy in there.
Old Feb 1, 2015 | 07:56 PM
troymn's Avatar
troymn
They have a little movement when they are in.
Old Feb 1, 2015 | 08:01 PM
resonateur's Avatar
resonateur
Troy, when you get it sorted out, if it turns out you need a set of I beams let me know. I have a pair from an f100... Only they would be heavy as h*** to ship.
Eric
Old Feb 1, 2015 | 08:18 PM
troymn's Avatar
troymn
Thanks resonateur!
Old Feb 2, 2015 | 01:02 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6TZ-3006-C .. Right I-Beam / Stamped: C5TA-3008-A or B or E / C7TA-3008-A or C8TZ-3008-B / Obsolete
C6TZ-3007-C .. Left I-Beam / Stamped: C5TA-3009-A or B or E / C7TA-3009-A or C8TA-3009-B / Obsolete
1965/70 F100 2WD / 1965/67 F250 / 1968/70 F250 with drum or disc brakes / 1971 F100 2WD & F250 with drum or disc brakes before serial number M00,001.
1965/67 E100 / 1969/70 E100/200 / 1971 E100/200 before serial number M00,001.
Old Feb 2, 2015 | 07:57 AM
troymn's Avatar
troymn
Thanks Numberdummy!
daiges
May 24, 2019 09:07 AM
Osiyo59
Jan 28, 2015 12:23 AM
yargnitram
Jul 10, 2011 10:13 AM
biggut
18
Dec 23, 2008 12:06 PM
grw289
May 6, 2003 07:25 AM
