77 F100 ENGINE SWAP
Old Aug 23, 1999 | 03:19 AM
TROY OGLE
Guest
Posts: n/a
77 F100 ENGINE SWAP
300 6cyl. 3 speed want to install a windsor and c6 wanted to know if my engine mount stand will work or if i will need ones for a small block if so what year will work and on my cross member
Old Aug 26, 1999 | 06:14 PM
MSTRAWN's Avatar
MSTRAWN
77 F100 ENGINE SWAP
Would like to share information on this subject with you as I obtain it. I am presently building a 302 stroker to go in my '77 F-100 with 300 I6 and C-4. The C-4 will be replaced with a modified AOD. I have access to the Ford Shop Manuals with part numbers. I only get online about every three days so hang in there.
Old Aug 26, 1999 | 07:33 PM
jowilker's Avatar
jowilker
77 F100 ENGINE SWAP
Troy, get the stands when you get the engine, also you will need the driveshaft, the radiator, steering column, shifting rod.
Buy the donor and keep it until you have completed the changes.
good luck
John
Old Aug 27, 1999 | 05:17 PM
MSTRAWN's Avatar
MSTRAWN
77 F100 ENGINE SWAP
john mullen
48
Jun 20, 2022 04:50 AM
Tepot
May 11, 2016 07:32 AM
rhenderson1965
Engine Swaps
Apr 24, 2015 12:27 PM
Bubba-88
13
Nov 29, 2014 08:42 AM
txwing
41
Aug 9, 2004 08:17 PM
