uhm, ROG.
Could you show us a picture of this dude....
Cause. I have no clue how you get up from the bottom for the back bolt.
William:
I don't have a photo but I'll try to walk you through this. Start on the driver's side, lay down, schooch under the truck to the pass. side, reach up with your right arm with the proper wrench in hand and remove the cap screw (Bolt). IIRC there is also a ground strap connected to this area and that in it's self makes the replacement of this screw a real bitch to replace and I just left it off.
Also................ see 84 f250's post.
Hope this helps.
Rog
