Starting issues
Old Jul 18, 2016 | 05:14 PM
Pruitt66's Avatar
Pruitt66
Starting issues
I have a 66 f100 with a 352. I am trying to get it to start and am having some issues. The ignition switch wiring is fried so I am jumping off the solenoid. The truck will try and start but as soon as I pull off the solenoid it dies. Any ideas?
Old Jul 19, 2016 | 09:38 AM
Filthy Beast's Avatar
Filthy Beast
Hope this helps.
Go here:
https://www.ford-trucks.com/forums/1...1966-f100.html
Old Jul 19, 2016 | 10:07 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If it's still got points, connect +12 from the battery to the +12 on the coil. Then, jump the solenoid like you've already done. If it runs, yank that jumper wire off the coil and let it die. Since it's got an in-line resistor, the direct +12 can overheat the coil pretty quick. But at least, you tested the system
At that point, you need to redo the ignition switch wiring... Good luck
Let us know how it goes.
bunchoftrucks
Mar 9, 2018 03:35 AM
webersa4
13
Aug 1, 2016 08:29 PM
puroford
Jul 5, 2011 09:04 AM
first rebuild
Feb 20, 2011 02:49 PM
bobg
Mar 23, 2004 09:56 AM
