FICM question
Old Jan 27, 2010 | 11:11 AM
NauticaEE's Avatar
NauticaEE
FICM question
Hi fellas, I have an 05 6.0 and an 07 6.0, the dealer claims the FICM is bad on the 05 so i was wondering if i could take it off of the 07 and put it on the 05 to test if thats the problem......is this possible? or will it not work? thanks alot
Old Jan 27, 2010 | 11:53 AM
1954oldred's Avatar
1954oldred
You could simply check the voltage on the 05 w/a multimeter. Its not very difficult at all. remove the small cover on the top of the FICM (two 10mm torx screws) You should see 4 pins, Then on the pin closest to the drivers fender test for the volts w/KOEO, You should be seeing 48 v. Make sure this is done on a "cold" engine.
Old Jan 27, 2010 | 12:42 PM
Cowboy65's Avatar
Cowboy65
NauticaEE, welcome to FTE.
There are three threads in the Tech Folder that may provide valuable info on the FICM, testing, and repair. Links follow:
https://www.ford-trucks.com/forums/8...procedure.html
https://www.ford-trucks.com/forums/9...procedure.html
http://www.fordtechservice.dealercon...FICM_Guide.pdf
Old Jan 27, 2010 | 01:58 PM
texans's Avatar
texans
as stated above you could just test it to see what volts it has, but yes you can just switch the ficm if that is what you want to do.
Old Jan 27, 2010 | 03:04 PM
NauticaEE's Avatar
NauticaEE
Thanks alot for all the info and all the welcomes, sweet site!! thanks again
ricskstem
Engine Swaps
Sep 28, 2015 09:48 AM
revolverivar
Oct 8, 2012 11:45 PM
Curt's05
Apr 8, 2012 12:34 PM
j-bar
Nov 3, 2011 09:18 PM
