FICM ???
Old Nov 2, 2011 | 12:39 PM
j-bar's Avatar
j-bar
FICM ???
what should the readings on the ficm be for a 07 f350 6.0 powerstroke.
Old Nov 2, 2011 | 12:42 PM
NewToDiesels's Avatar
NewToDiesels
48 volts at KOEO, while cranking, low idle, and 2500 RPMs.
https://www.ford-trucks.com/forums/8...procedure.html
Old Nov 2, 2011 | 12:54 PM
j-bar's Avatar
j-bar
had the truck hooked up on a computer @ a local shop last night on the road @ full operating temp and the readings were @ ficm logic power 3.38 volts fimc main 12 volts ficm vehicle 3.38 volts.
Old Nov 2, 2011 | 12:57 PM
NewToDiesels
There is a FICM logic pwr PID that should be right at 12 volts. FICM main power should always be at 48.
Old Nov 2, 2011 | 01:00 PM
NewToDiesels
Forgot, there's also a FICM vehicle power PID that be at 12 volts as well. Those readings are way off - they can't be right if your truck is actually running.
Old Nov 2, 2011 | 01:20 PM
balzdeep05''s Avatar
balzdeep05'
i think in the tech folder there is a good thread on the ficm look there
Old Nov 2, 2011 | 01:46 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
j-bar-
I might know you. Is this John?
Old Nov 2, 2011 | 01:57 PM
j-bar's Avatar
j-bar
No its not John.
Old Nov 2, 2011 | 02:02 PM
Rusty Axlerod's Avatar
Rusty Axlerod
+1. I don't think vehicle would run with FICM main power that low.
Old Nov 2, 2011 | 06:19 PM
cheezit's Avatar
cheezit
lowist I have seen run is 21v. ran like crap though
Old Nov 2, 2011 | 10:20 PM
j-bar's Avatar
j-bar
truck seems to be weak when you hit some steep grades.
Old Nov 2, 2011 | 10:33 PM
NewToDiesels
Something is wrong with their equipment since your truck actually runs. There is definitely something wrong, and it just may be the FICM. BUT the results they are getting are not consistent with a running truck.
You should check it with a volt meter and see what you get. The procedure is simple and it's in the Tech Folder.
Old Nov 3, 2011 | 09:18 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
+1. The issue sure MAY be the FICM, but could be loads of other things as well. First step is to pull codes if you can. If you can't, check output voltage on the FICM pins.
Ed
Ed@ficmrepair.com
RobertDaharsh
May 15, 2019 03:11 PM
brianmoody35
Sep 29, 2016 02:24 PM
Poorboy04
Aug 5, 2013 09:54 PM
RideDiesel88
Dec 5, 2012 08:48 PM
reamer
Aug 20, 2007 08:44 PM
