Split gear trany
Old Jan 26, 2010 | 09:00 AM
4x4jedi's Avatar
4x4jedi
Split gear trany
I just noticed an f600 on craigs list with a 429ci and a 5spd trans. I'd that sething we could adapt to make an "economy"/overdrive??
I'm not totaly shure how z split trans shift patern works so if I'm totaly off please set me straight. Knoledge is power
Old Jan 26, 2010 | 09:17 AM
4x4jedi's Avatar
4x4jedi
That's a 5spd split shift
Old Jan 27, 2010 | 09:50 PM
Mike in Ohio's Avatar
Mike in Ohio
Usually those are a 5 speed tranny with a 2 speed rearend. If you start in 1st gear low then you flip the switch and bump the clutch pedal to go to high, Then you shift into 2nd and at the same time flip the switch back to low. When at he proper rpm you flip the switch again to high. Then 3rd low and on and on.
An f600 rearend would be a bit large and probably geared too low for a 1/2 or 3/4 ton.
Mike
Old Jan 27, 2010 | 10:07 PM
4x4jedi's Avatar
4x4jedi
Well that's no good. I was hoping it was more along the lines of an overdrive unit on the tail housing like in a 4x4. Oh well.. I have a f350 I plan to ditch the dual D60 and throw in a D44 untill I can aford a 9inch
Excursion4X4
57
Jun 22, 2009 12:51 PM
wesh
Nov 11, 2006 12:07 AM
seventyseven250
Sep 22, 2006 06:32 PM
fejetmech
Aerostar
Jan 28, 2003 05:10 AM
elliott
Dec 7, 2002 12:40 PM
